  • Guests: 58
Junky QCW
1 2 3 4
zrg
Fri May 03 2013, 08:51PM Print
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
Just wanted to share some nice shots of a QCW DRSSTC test rig we've been updating today. Originally it had a buck with IRGP50B60PD1, and a bridge with same IGBTs, now updated to a double bridge, and a boost converter before the buck (again on 50B60), which rises the voltage to ~410VDC and charges the 2x12000uf CDE electrolytics.
125x250 mm secondary with a ~420 kHz freq gives nice 2+ meter swordlike sparks, maximum recorded shot is ~220 cm.
1367614153 4762 FT0 Dsc 9866
1367614153 4762 FT0 Dsc 9874
1367614153 4762 FT0 Dsc 9875
1367614153 4762 FT0 Dsc 9881
The current limiter is set to 300A, which gives us ~60 kW of peak power through buck. It's amazing how much these small transistors can withstand cheesey However, in the end it banged with several kJ from lytics coming into my poor ears.
1367614153 4762 FT0 Dsc 9885
1367614153 4762 FT0 Dsc 9887
1367614153 4762 FT0 Dsc 9888
Fri May 03 2013, 09:20PM
Very, very sweet!!!
I absolutely love it. That coil has true SOUL!!!!
Your work area reminds me of the late legendary Jim Williams' famous work bench.
You are both true masters of analog electronics!!!!!
RateReducer
Sat May 04 2013, 12:29PM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
This is just amazing! amazed
zzz_julian_zzz
Sat May 04 2013, 12:53PM
Hi, how long are the ramp you are using? thanks for sharing this wonderful coil! very great!
zilipoper
Sat May 04 2013, 01:13PM
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
Ho Ho Ho worthy of
loneoceans
Sat May 04 2013, 01:39PM
Wow zrg, that looks fantastic!
zrg
Sat May 04 2013, 01:49PM
zzz_julian_zzz wrote ...
Variable 10-20 ms, shots are made at ~15 ms
zzz_julian_zzz
Sat May 04 2013, 03:13PM
HI Zrg, thanks for the reply..
actually, im current assembling my QCW bus modulator, could you give me some advice with my schematic below? i only have LM311 (voltage comparator) this is the only Voltage comp available here in my country... I used the first one to make the 'hysterizer' and the other for the detector/convert to logic 1 & 0, since the output of the first LM311 is not 1 & 0 but a signal in a form of a ramp,, i would like to know if this IC(LM311) / overall circuit can work? thanks a lot.. :)
1367680379 3964 FT153579 Schem Qcw Bus Mod
1367680379 3964 FT153579 Waveform Qcw Bus Mod
 Qcw Controller
Mr.Black
Sat May 04 2013, 03:36PM
Mr.Black Registered Member #3960 Joined: Mon Jun 20 2011, 06:27AM
This is amazing!
teravolt
Sat May 04 2013, 05:00PM
I like your lab the best but the coil piezoresistance.
