  • Guests: 57
SSTC waveform ringing problem
hsieh
Wed May 01 2013, 06:50AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I measured the waveform of my SSTC And I found serious ringing problem on my gate drive waveform.I increase my gate resistor but it didn't help.Later I found the input of UCC37321/2(output of 74HC14) is also ringing.Sometimes when I draw an arc, the ringing disappears.
My MOSFET heat up fast.I think this ringing might be the reason.What can I do to stop ringing?
My test setup. 25VAC input.half bridge MiniSSTC with voltage doubler.
1367390434 1412 FT0 Dsc 01221
Channel 1 is MOSFET Vgs. Channel 2 is primary current.Channel 3 is primary voltage
1367390434 1412 FT0 Dsc 01231
Channel 1 is MOSFET Vgs. Channel 2 is input of UCC37321/2(output of 74HC14).
1367390434 1412 FT0 Tek00002
Thanks
Wed May 01 2013, 07:03AM
Hi, I'm pretty sure the ringing you see on the gate waveform, is interference the scope or its probe are picking up from the power circuit.
Physics Junkie
Wed May 01 2013, 07:08AM
Physics Junkie Registered Member #7267 Joined: Tue Oct 16 2012, 12:16AM
I agree. I get that from time to time. Also, your circuit looks really close to the coil, try shielding it and/or moving it away a little bit. You might find less interference on your probes when they are further from the coil, and same goes with the circuity. I wouldn't use more than 5.1 ohm gate resistors
