  • Guests: 50
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
What the heck is this cap!?
coillah
Tue Apr 30 2013, 04:12PM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Hi guys, I can't figure out what this cap is. It is a ceramic (I think), rated, 102 (OK so 1nF), C1K... What does the C1K stand for?
Tue Apr 30 2013, 05:34PM
Likely the dielectric type as in Class 1 dielectric which has a very good temp coefficient.
coillah
Tue Apr 30 2013, 06:03PM
Damn. I was hoping it wasn't... Difficult to find those caps...
Nevermind. I can just spec C0 and those are easy to get.
Moderator: Use the edit function and do not double post!
Tue Apr 30 2013, 11:14PM
Is this something you are trying to repair / replace?
Whats the application? I can't see you needing something better than NPO / C0G.
Wed May 01 2013, 09:45PM
In the EIA RS-198 standard for Class 1 ceramic capacitors - for C1K - C specifies the temperature coefficient in ppm/K as 0.0, the next number is the temperature coefficient multiplier, and the letter code K is the temperature coefficient tolerance ±250.
