  • Guests: 56
weird popping spark output
Physics Junkie
Tue Apr 30 2013, 03:05AM Print
Physics Junkie Registered Member #7267 Joined: Tue Oct 16 2012, 12:16AM
went for first light on my new drsstc. got this weird popping output like firecrackers. I double checked my gate waveforms to make sure that there wasnt some sort of problem with the drive signal but it was still fine looking. has anyone experienced something like this?
350VDC at the bridge
75uS PW
Full bridge of Link2
68kHz secondary
My first guess is a tuning error. Possibly too low. It was getting late so I'll have to mess with the primary more tomorrow.
Tue Apr 30 2013, 07:29AM
Reminds me of my first SSTC when it was interfering itself, additional(I had none) shielding of everything solved the problem.
Physics Junkie
Tue Apr 30 2013, 03:34PM
Everything is shielded. Driver is in aluminum box, grounded. Chicken wire around the whole base structure also grounded.
Edit: I suppose I could find a large computer case or something similar to put the whole bridge in. But its rather bulky. Guess it couldn't hurt to try it. Thanks
Physics Junkie
Thu May 02 2013, 03:12AM
Hows this for shielding? smile
1367463762 7267 FT153500 Img 20130501 202457 947
1367463763 7267 FT153500 Img 20130501 202523 347
1367463763 7267 FT153500 Img 20130501 214325 387
Made a custom all aluminum box for everything. With aluminum mesh around the whole base now instead of chicken wire.
I'm grateful for the suggestion, it made a huge difference, the sparks breaks out like it is supposed to. But not totally solved. I get popping at about 400VDC still (the popping sparks are pretty big too). When monitoring the current I see a huge spike every time it "pops" which trips the OCD each time. Still think this is a shielding issue?
