  • Guests: 50
Semi QCWSSTC
zzz_julian_zzz
Mon Apr 29 2013, 09:59AM Print
Hi everybody,
Can someone help me with a circuit that can sync the interrupter on the AC mains? this will be for my Semi QCW SSTC. (Stacato)
To accomplish sword like sparks, the ramp of my AC(60hz) should be sync with the interrupter... the problem is i dont know how. Any idea for the circuit? thanks.
Mon Apr 29 2013, 10:48AM
Use something like the first 555 stage here. Link2
Mon Apr 29 2013, 01:53PM
Well usually you can leave the gate driver running all the time, if it can cope with the heat generation. Maybe you wanted "pulse skipping" like it is done with VTTCs? Then you can try this circuit and modify it, or add a monostable circuit to it. Link2
zzz_julian_zzz
Thu May 02 2013, 02:10AM
Thank you for sharing these very informative circuits., On my first look, it seems that they are 'identical' in some way.. I'll try this circuit later this evening thanks again,
