  • Guests: 45
CNC tables
Thu Apr 25 2013, 09:10PM Print
Hey guys,
I know several of you are CNC enthusiasts,
ive been looking for the aluminium t-slot tables to
use as a cnc router base.
anyone know the proper name for them
or where i can get them, been looking everywhere!
thanks,
Thomas Williamson
Ben Solon
Fri Apr 26 2013, 12:11AM
The first page of google turned this up: Link2 As for the ones that are already cut, drilled and tapped, I don't think they don't make them as separate parts.
Fri Apr 26 2013, 01:04AM
Are you planning on using a spoilboard with your set-up? If so, i would research some examples on how hold done is accomplished with a spoilboard as this may influence what type of base you use with your CNC router.
Depending on the type of hold down techniques you are using, you may not need the T-slotted base.
Ash Small
Fri Apr 26 2013, 09:11AM
Are you just after the 'T' slot plate, or the whole 'sliding table' (some suppliers seem to use the term 'slide table', but I've always called them 'sliding tables').
Fri Apr 26 2013, 09:45AM
Some DIY routers I've seen just use a piece of MDF for the table, and I guess the workpiece is screwed to it with woodscrews. When the MDF gets too full of holes just replace it. I suppose this is what EVR refers to as a spoilboard.
Fri Apr 26 2013, 12:25PM
Steve Conner wrote ...
Yes, that is correct. The spoilboard is just that - a spoilboard. Generally MDF is used for a spoilboard and it if first planed using a large surfacing bit to make the top surface of the spoilboard perfectly flat with respect to the Z axis. Then if the CNC machine is set-up properly, you will almost never cut into the spoilboard. But as it is a spoilboard, if you do cut into it by accident, or whatever, it is easily replaceable. Most CNC router manufacturers have a built in program to prepare their own spoilboard for their particular table - some even including provisions for T-Slots or other hold-down type hardware and/or vacuum table slots etc...
Fri Apr 26 2013, 02:44PM
ben123324 wrote ...
Yes, that was what i was looking for, anyone know anywhere cheaper as for me that is damn expencive
or is that pretty much the cheapest il be able to get?
im looking for about 500mmx500mm
Thanks,
Thomas williamson
