  • Guests: 27
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
SSTC tech question
Wed Apr 24 2013, 07:53PM Print
Hi,
does the primary current of an interrupted SSTC ring up above the steady-state value in the beginning of every pulse, like in a DRSSTC? I have no ISSTC handy, otherwise I would simply measure it... Thanks for your replies. smile
Sigurthr
Wed Apr 24 2013, 08:24PM
I can't measure primary currents but secondary base current doesn't appear to exceed steady state.
Sun Apr 28 2013, 03:22AM
The current is related to the Q of the coil. Higher Q means it can ring up to higher levels of stored energy, which implies higher primary currents. Before the resistance of the plasma drops sufficiently, the Q can look quite large and so the primary current will almost always ring up highest at the start of the pulse, and then get pulled down as the plasma dampens the tesla coil and the Q drops to some steady-state value determined by all the losses and the plasma.
Sun Apr 28 2013, 07:58AM
Thanks Steve smile
