  • Guests: 59
Strange old Tesla coil no2
AlgoryThm
Tue Apr 09 2013, 04:21AM Print
AlgoryThm Registered Member #4134 Joined: Tue Oct 11 2011, 12:34AM
Hello again! Well it seems my curiosity about vintage tesla coils led me again to discover a strange (for me at least) tesla coil. I'm posting the picture below. So I have a couple of questions, because I can't understand completely how it works.
1) It seems that there are three coils in total, two secondaries and one primary in the middle. I put it on the JAVATC (it accepts only one secondary and primary) and it gave me back that primary is tuned 50% higher compared to the secondary. It oscillates at around 700khz and the secondary at around 350khz. Is JAVATC wrong or this is the case here? My guess was that this happens because primary has to transfer energy to both secondaries so 350+350=primary's frequency?
2) Why are the two secondaries literally connected to the primary this way? Each secondary has one side of the coil connected to one side of the primary. Does this give some kind of tuning?
3) Does this work as a bipolar tesla coil? And because I am very curious about how it works in real life and I'm willing to build one, how could I tune a bipolar tesla coil like this one?
Thank you very much for your time and any forthcoming help!
2
Sigurthr
Tue Apr 09 2013, 04:38AM
Looks like a pretty standard Bipolar SGTC to me. The only strange thing is the low secondary turns count; 140 in total.
It isn't really two secondaries, there is just one secondary and the primary is overlaid in the center - the primary and secondary are not directly connected, it just appears this way because of the drawing.
edit: removed an error my tired eyes should have caught!
Shrad
Tue Apr 09 2013, 07:20AM
I agree each side of the secondary is connected to one of the ends of the primary, making some kind of bipolar air-core autotransformer with a ratio of 1:15 or something
AlgoryThm
Tue Apr 09 2013, 12:02PM
Thank you both for your answers! So if the secondary is actually connected to the primary, how do I fine tune it? Is the primary oscillating at double of each secondary's frequency or both 3 coils have to to resonate at the same frequency? I mean Xfreq of secondary + Yfreq of the other secondary = primary's frequency, or X=Y=Primary's frequency? Even following your method Sigurthr, JAVATC gives me back that primary is tuned 43-45% higher!
Tue Apr 09 2013, 12:52PM
Use one half of the secondary in JavaTC.
The other half is identical, so the ends must develop equal and opposite voltages, hence the centre must be at ground potential. It follows that you get the same resonant frequency if you cut it in half and replace the missing half with a ground plane. (this is called the method of images)
Because the primary voltage is much smaller than the secondary voltage, this argument is still more or less true if the secondary is connected to the primary.
AlgoryThm
Tue Apr 09 2013, 01:39PM
I see...Thank you Steve, I just tried it your way and it seems that either they built it out of tune on purpose or they didn't have JavaTC to calculate the exact length of wire they needed! Lol! I have an idea though as to why they built it this way. The coupling coefficient in bipolar coils is usually huge and we need much bigger formers for primaries in order to avoid internal coil sparks. JavaTC gives me back a number 0.4 to 0.7 (depending on the former size) when it is perfectly tuned. So at this coupling, lots of internal sparks are to be expected and so I think they made it out of tune on purpose to avoid this kind of phenomena. When it is given as they did it, the coupling is around 0.20 to 0.25. Just a theory though...We'll see what happens when I have it ready...
