  • Guests: 39
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
Universal DRSSTC Driver V2.5 (Sold Out)
Linas
Mon Aug 11 2014, 03:48PM
I am developing ( well, copying) DRSSTC controller based on U2.5.
I have some questions:
CT transformer don't have any real loading on frequency feedback, only 50R resistor+inductor. if i have 1:300 transformer, that will mean very high voltage on input node. Also inductors use very thin windings. Is it good idea to keep that way, if bridge can push 2-3kA? (CM600 Full bridge)
Also i will add interrupter monitoring, so even if i have 1 at input, it will shut down my driver before IGBT will be killed.
1407937727 1143 FT152849 Drsstc
Vitalii
Mon Sept 01 2014, 02:27PM
Vitalii Registered Member #46012 Joined: Thu May 01 2014, 12:54AM
Hi!
I finished build this board two days ago. Any idea how to start use it. I feel lack of documentations for people like me (I spent only day to build it but it's my first experience wirh DRSSTC and with UD 2.x drivers).
I have 2ch oscilloscope, multimeter and regulated power adapter 5-35V and fixed voltage 60+120 V (500W) power supply.
Also I have gate from this schema DRSSTC3.
Can you kindly assist me to start as safe as possible (don't damage components of UD 2.5) and give advice (or maybe there's a checklist) how to check that UD 2.5 assembled fine?
jay
Thu Oct 09 2014, 12:53AM
jay Registered Member #1346 Joined: Fri Feb 22 2008, 05:48PM
Eric,
I'd like to buy 1 of your boards, if you still have any left.
Thank You
Wed Dec 24 2014, 03:15PM
I am testing a UD2.5A board that I just completed. voltage rails all looked good. I have D13 removed as I am not using the IF receiver. Added in the R21 resistor and now the OCD LED comes on. Before adding R21 it did not. Looking at the circuit, I don't see why it would come on without any OCD current. Anyone else seen this?
loneoceans
Wed Dec 24 2014, 06:23PM
It's normal for the OCD light to turn on during startup (is this what you meant?) This is just the behavior of the 74HC74 flipflop starting in that state. I actually use it as a good indicator if my interrupter line is working by sending a pulse which should clear it when triggered.
Fri Dec 26 2014, 03:38AM
Yes - that is what I mean. When starting up with no FB or OCD signals the OCD LED comes on. If this is normal, then I will proceed with testing.
Thanks a bunch.
Vitalii
Mon Feb 09 2015, 10:34AM
Hi!
Third time burned FDD8424H (U3 on the board).
So what I do:
I power the driver from DC-source - 6S LiPo battery (25.2V but 24 with load). I removed B1 rectifier (to prevent 0.7 voltage drop on it).
When I power on the driver from 12V - it works as expected.
But 24V power source burns U3 each time when I try to power it on. I tested with GDT connected and disconnected - usually the same result. (but there's no shorts on the board, I checked at least 5 times).
I'm not sure about U1 and U2, because they are not installed.
But U4 doesn't burn!!
I checked FDD8424H datasheet - it can work up to 40V.
Please give me an advice how to solve the problem?
hen918
Mon Feb 09 2015, 07:27PM
Vitalii wrote ...
Hi!
So what I do:
sorry, I haven't looked at the schematics, but couldn't it be some inductive element causing high(er) voltage back EMF?
Vitalii
Tue Feb 10 2015, 04:25PM
ok. I found a real cause of this stupid issue.
It's a problem with board tracing. I'm not sure where's the mistake but it can be in Gerber-files. In other case it's a mistake that happened on board printing machine.
2 lanes on the board that connect U1 and U3 sources to R12 and R22 were not connected. As a result one of gates had 22V.
Signal on U1 Gate1:
SDS00007
Signal on U1 Gate2:
SDS00008
Error on the board (marked pink):
I add all this data to tread because somebody may have similar behavior - Driver works fine on 12 V but burns on 24V.
Now it works fine from 25V source without B1 rectifier!
Aragorn
Wed Feb 14 2018, 02:47PM
Aragorn Registered Member #18516 Joined: Sat May 18 2013, 09:09AM
Anyone got a mirror of the board files/schematics etc for the UD2.5 board that were originally hosted on Erics Google Drive?
The link on the blog is dead.
