  • Guests: 76
12/25 Kolas (18)
12/26 buxtronix (50)
Simple stepper driving with PIC16F628
dingo27
Fri Mar 29 2013, 06:22PM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Hello all, this is a thread to show code i want to program for driving stepper motors, currently we have an ongoing talk bout it in chatroom, so for clearer help i am posting it here. Feel free to modify and use in any way.
BE AWARE IT IS NOT FINAL CODE
#include <p16F628A.inc>
    __CONFIG (_PWRTE_ON & _WDT_OFF & _BODEN_OFF & _LVP_OFF & _INTRC_OSC_NOCLKOUT)
    org 0
#DEFINE         TLACH       PORTA,1 ; tlacidlo nahor
#DEFINE         TLACD       PORTA,2 ; tlacidlo nadol
#DEFINE         TLACSET     PORTA,3 ; tlacidlo set
#DEFINE         TLACL       PORTA,0 ; tlacidlo vlavo
#DEFINE         TLACR       PORTA,7 ; tlacidlo vpravo
#DEFINE         BUSY        PORTB,0 ; Busy
#DEFINE         O1          PORTB,7 ; vystupy pre krok motor
#DEFINE         O2          PORTB,6 ;
#DEFINE         O3          PORTB,5 ;
#DEFINE         O4          PORTB,4 ;
#DEFINE         XAXIS       PORTB,1 ; led a enable pre X os
#DEFINE         YAXIS       PORTB,2 ;
#DEFINE         ZAXIS       PORTB,3 ;
mem1      equ         20h
mem2      equ         21h
mem3      equ         22h
mem4      equ         23h           ; hodnota odchylky
memX      equ         24h           ; hodnota kroku
memY      equ         25h           ; hodnota kroku
memZ      equ         26h           ; hodnota kroku
Start:
    MOVLW       B'00000111'
    MOVWF       CMCON
    bsf         STATUS,RP0          ;
    MOVLW       B'11101111'         ; Busy(A4) output
    MOVWF       TRISA               ;
    MOVLW       B'00000000'         ; PortB vystupny
    MOVWF       TRISB
    bcf         STATUS,RP0          ; back to Register Page 0
    BCF         O1                  ;vynuluje vsetky vystpy
    BCF         O2
    BCF         O3
    BCF         O4
    BSF         XAXIS
    BCF         YAXIS
    BCF         ZAXIS
    BCF         BUSY
    MOVLW       10                  ;nastavi pociatocnu rychlost 10
    MOVWF       mem4
    MOVLW       B'00010001'         ;
    MOVWF       memX
    MOVWF       memY
    MOVWF       memZ
    GOTO        MainLoop
Odchylka:
    CLRF	mem1                    ; podprogram ochylka
	MOVLW	15                      ; zmenou tohoto cisla muzete zmenit rychlost
	MOVWF	mem2
    MOVFW   mem4                    ; nakopiruje hodnotu z mem4 do mem3, aby m4 ostalo rovnake aj nabuduce
    MOVWF	mem3
    GOTO    Subrutina
Subrutina:
	INCFSZ	mem1,1
	GOTO	Subrutina
	DECFSZ	mem2,1
	GOTO	Subrutina
    DECFSZ	mem3,1
	GOTO	Subrutina
	RETURN
MainLoop:
    BTFSC       TLACSET
    GOTO        Setmenu             ; vyvola setmenu na nastavenie rychlosti
    BTFSC       TLACR
    GOTO        RotR                ; rotuj vystup vpravo X/Y/Z
    BTFSC       TLACL
    GOTO        RotL                ; rotuj vystup vlavo Z/Y/X
    BTFSC       TLACH               ; sprav krok vpravo v aktivnej osi
    GOTO        StepR
    BTFSC       TLACD               ; sprav krok vlavo v aktivnej osi
    GOTO        StepL
    GOTO        MainLoop            ;vracia sa na hlavny program
StepR:
    BSF         BUSY
;part1
    BCF         O4
    BSF         O1
    CALL        Odchylka
;part2
    BCF         O1
    BSF         O2
    CALL        Odchylka
;part3
    BCF         O2
    BSF         O3
    CALL        Odchylka
;part4
    BCF         O3
    BSF         O4
    CALL        Odchylka
    BCF         O4
    BCF         BUSY
    GOTO        MainLoop
StepL:
    BSF         BUSY
;part1
    BCF         O1
    BSF         O4
    CALL        Odchylka
;part2
    BCF         O4
    BSF         O3
    CALL        Odchylka
;part3
    BCF         O3
    BSF         O2
    CALL        Odchylka
;part4
    BCF         O2
    BSF         O1
    CALL        Odchylka
    BCF         O1
    BCF         BUSY
    GOTO        MainLoop
RotR:
    CALL        Odchylka
    BSF         BUSY
    BTFSC       TLACR
    GOTO        $-1
    BCF         BUSY
    BTFSC       XAXIS               ;ak je x aktivna, nastavi aktivnu y
    GOTO        SetActiveY
    BTFSC       YAXIS               ;ak je y aktivna, nastavi aktivnu z
    GOTO        SetActiveZ
    BTFSC       ZAXIS               ;ak je z aktivna, nastavi aktivnu x
    GOTO        SetActiveX
    GOTO        MainLoop
RotL:
    CALL        Odchylka
    BSF         BUSY
    BTFSC       TLACR
    GOTO        $-1
    BCF         BUSY
    BTFSC       XAXIS               ;test ci je X axis 1
    GOTO        SetActiveZ
    BTFSC       YAXIS
    GOTO        SetActiveX
    BTFSC       ZAXIS
    GOTO        SetActiveY
    GOTO        MainLoop
SetActiveX:                         ;nastavi os X ako aktivnu
    BSF         XAXIS
    BCF         YAXIS
    BCF         ZAXIS
    GOTO        MainLoop
SetActiveY:                         ;nastavi os y ako aktivnu
    BCF         XAXIS
    BSF         YAXIS
    BCF         ZAXIS
    GOTO        MainLoop
SetActiveZ:                         ;nastavi os z ako aktivnu
    BCF         XAXIS
    BCF         YAXIS
    BSF         ZAXIS
    GOTO        MainLoop
krokXL:
    BSF         BUSY
    RLF         memX,1              ;vyrotuje akukolvek hodnotu v pamati memx
    CALL        Odchylka
    BCF         BUSY
    GOTO        MainLoop
krokYL:
    BSF         BUSY
    RRF         memY,1
    CALL        Odchylka
    BCF         BUSY
    GOTO        MainLoop
krokZL:
    BSF         BUSY
    RRF         memZ,1
    CALL        Odchylka
    BCF         BUSY
    GOTO        MainLoop
krokXR:
    BSF         BUSY
    RRF         memX,1
    CALL        Odchylka
    BCF         BUSY
    GOTO        MainLoop
krokYR:
    BSF         BUSY
    RRF         memY,1
    CALL        Odchylka
    BCF         BUSY
    GOTO        MainLoop
krokZR:
    BSF         BUSY
    RRF         memZ,1
    CALL        Odchylka
    BCF         BUSY
    GOTO        MainLoop
Setmenu:
    BSF         BUSY                    ;indikuje vstup do nastavenia
    CALL        Odchylka
    BTFSC       TLACSET                 ;skontrolovat ci je tlacidlo este stlacene,
    GOTO        $-1                     ;skace ak je 0, preskoci navrat a pokracuje
    MOVLW       10
    BTFSC       TLACH                   ;ak je tlacidlo stlacene, skoci dalej a pricita W ku mem4
    CALL        RychlH
    BTFSC       TLACD                   ;ak je tlacidlo stlacene, skoci dalej a odcita W ku mem4
    CALL        RychlD
    BCF         BUSY                    ;zhasne pre opustenie menu
    BTFSC       TLACL
    GOTO        MainLoop
    GOTO        Setmenu
    GOTO        MainLoop                              ;navrat z podprogramu
RychlH:
    BCF         BUSY
    BTFSC       TLACH                   ;ak je TlacH stlacene, vrati o jeden dozadu
    GOTO        $-1
    INCF        mem4,O'10'              ;Odrata hodnotu W
    BSF         BUSY
    RETURN
RychlD:
    BCF         BUSY
    BTFSC       TLACD                   ;ak je TlacD stlacene, vrati o jeden dozadu
    GOTO        $-1
    DECF        mem4,W
    BSF         BUSY
    RETURN
    GOTO        MainLoop
    END
EDIT>
BUG1: Switching between outputs fixed (with TLACR/TLACL)
BUG2: Switching from setting menu fixed (not able due to getting into it, changed to TLACR for leaving. Added delay(odchylka) for startup
BUG3: PORTB:4 double defined, fixed
BUG4: BUSY signal could not get out of PORTA:4 for unknown reason to me, switched to PORTB:0, now indicates fine.
BUG5: Delay shortening/longering does not work, something wrong with sintax of RychlH part (INCF)
BUG6: Remembering of last step position not working yet, currently makes all 4 steps at once so it can continue from same place even when outputs are switched
Ash Small
Fri Mar 29 2013, 07:25PM
I'm also working on a driver for two stepper motors for a coil winding machine (I should be posting something this weekend). I envisage that my control program will be a lot simpler than this. I'm debating at the moment whether to use two I/O pins for each stepper motor, or four.
I'm planning to keep mine as simple as possible, and to control it from an Andriod phone and Rasberry Pi. but it's interesting to see how others go about it.
Bjørn
Sat Mar 30 2013, 02:44PM
Doing things like "BCF PORTB,7" is unsafe.
The reason is that the processor will read the state of the pins, modify and write back. There are many reasons why pins could be in a different state than you expect. This sort of error is also extremely hard to debug simce it tend to go away when you start looking for it.
As an example PORTB contains 0b01000000:
BCF PORTB,6
BSF PORTB,7
If the capacitive load on Pin 6 is large enough the second instruction will read the pin as 1 and write it back, making the first instruction a no operation. If you single step through the code or simulate it the problem disappears.
So always build up your value in a memory register or accumulator, then move the whole byte to the port. That way there will be no read-modify-write cycle. More advanced microcontrollers have a special set bits register to avoid this problem.
Worst case is that your drivers and motors go up in flames or that the device will chop someones fingers off when noise/ringing on a pin flips a bit in the output register.
RA4 is an open drain output that can only sink current. If you want to source current you need to add a suitable pull-up resistor.
dingo27
Sat Mar 30 2013, 10:00PM
Bjørn wrote ...
Aaaah... the art of not reading the whole datasheet - my mistake.
For an update, currently i am trying to remember last step made and rotate next from that memorized value, with no luck yet. Will try to tinker with it a bit, or try other way.
Also, rotating enable XYZ outputs right works fine with 'i will not continue until you leave that button untouched' feature, but not to left, even when it is the same piece of code. (just different outputs and inputs). Rotating left is too fast even when there is same time delay as in rotate right...
Maybe reading outputs bug just appeared?
Wed Apr 03 2013, 10:27PM
Someone should write some code that implements microstepping from a PIC 16F628.
I had a thought about using four MC34063's in current controlled mode, to modulate the drives to each winding according to a lookup table.
Sound feasible?
