  • Guests: 68
Ordinary little tesla coil problem
Patric
Fri Mar 29 2013, 10:18AM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
I have racing arcs along the secondary and flashovers between the primary and the secondary. I removed one turn from the primary because I thought it was the wrong frequency, and I did put a tube filled with paraffin around the secondary, but it did not help much. What can I do next? Please help!
1364552266 2899 FT0 Tes12
Fri Mar 29 2013, 10:33AM
For a SGTC, the coupling between primary and secondary coil seems to be too high.
Fri Mar 29 2013, 11:01AM
Yes, I would make the primary conical, so it doesn't couple to the secondary just along a small length.
Fri Mar 29 2013, 01:18PM
I agree.
Too much coupling for a SGTC. Try changing your primary to a pancake style primary. You can use just regular 12 AWG wire to get the number of turns and tuning and then replacing with some thicker conductor once all the tuning is done.
Patric
Fri Mar 29 2013, 03:15PM
Thanks!!! I lowered the primary to the bottom of the secondary, and I removed one more turn. Now it is perfect!
Fri Mar 29 2013, 03:16PM
That will do the trick. Glad it worked out for you.
teravolt
Fri Mar 29 2013, 04:10PM
what kind of capacitor are you using? make your primary about 6" with 8 turns with #8 or small refrigerator tubing or wire. a pancake winding might be easier to make.
Patric
Fri Mar 29 2013, 07:02PM
I use 25 foil caps from 100 nF 1500V in series. The primary is now 5 turns copperwire 1.5 mm plastic isolated. Trafo is 10 kV 20 mA.
I get strikes from about 5 inch and more! Very happy!
Katya
Wed Apr 10 2013, 12:45AM
Katya Registered Member #9020 Joined: Wed Dec 26 2012, 12:11AM
I like the look of your tank circuit.
I typically maintain at least one inch clearance between the innermost primary turn and the secondary. I also extensively model with JavaTC before even spending a single cent. JavaTC conveniently suggests a minimal separation. Your favorite modelling program probably does the same.
Air, though it does break down, does not track. Adding the wax may increase the risk of tracking.
Patric
Wed Apr 10 2013, 08:25AM
Katya wrote ...
Thank you! I use teslascript/teslaform. I use very often wax, because it is such a good isolator, it can be removed, and it gave strength to the construction. Since I retuned the coil and lowered the primary, I had no down-streamers any more.
