  • Guests: 38
  • Members: 1
Bosko (56)
hen918 (30)
Yuri_Ivanov (35)
SoldierOhm (37)
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
My first ZVS
Whiplash
Tue May 07 2013, 07:00PM
Whiplash Registered Member #11363 Joined: Mon Mar 18 2013, 04:29PM
If Jozef C, i can use those transformers from a LCD Backlight inverter?
IMG 20130507 155415 414
Its use 2 chips: BIT3102b and a mosfet driver 9962GM.
I dont want use the driver, only the (2)transformers....
i dont have now a solder to remove the transformer, i dont know how much windings on primary.
but tonight i will see the windings.
Kiwihvguy
Wed May 08 2013, 06:34AM
Kiwihvguy Registered Member #3395 Joined: Thu Nov 04 2010, 08:42AM
I would highly recommend you don't use those tiny transformers for several reasons:
1. They are tiny; physically and power wise. If you start pumping a couple hundred of watts through those poor things, they will most likely go up in flames before you know it.
2. The primary probably isn't center-tapped. A ZVS driver requires a winding that is center-tapped.
3. It would be very impracticable to gave to fiddle with the tiny wires on that thing.
I don't see why would would need to use those things anyway, they are only designed to run small backlights and probably only put out 2-3 kV at less than 1 mA.
Just stick with the flyback, a lot more voltage and current possibilities.
Whiplash
Wed May 08 2013, 11:00AM
Hi, i know about the low power of those transformers, but i can make some portable hv device :P
I reserve my good flybacks for good 'projects' ^^
I flyback from a crt monitor will cost almost U$40,00 here =/ (R$80 local money).
My IRFP260 are on mail ....I cant wait anymore ahahah
