How can I test an RF transistor to see if its good or busted?
zero_coke
Tue Mar 19 2013, 03:17AM
Registered Member #8368
I have the MRF454 transistors and I need to test to see if I've damaged them or not. What's an accurate way of doing this?
Thanks!
zero_coke
Nevermind...I'll just see if the voltage drops are 0.4-0.7 V between Base and Collector and between Base and Emitter using the diode test function.
Shrad
Registered Member #3215
you could setup a small class A amplifier and stick it to the reference signal of your oscilloscope.. or setup a small oscillator
WaveRider
Registered Member #29
If the base bias voltage looks right and collector current behaves consistently, then the transistor is in all likelihood good. The back-to-back diode test is a good test of the BE-BC junctions as well...
