  • Guests: 93
01/12 RoV IW3IPD (63)
Moron Alert
1 2 3 4
Fri Aug 25 2006, 03:37PM Print
http://www.dailymail.co.uk/pages/live/articles/news/news.html?in_article_id=402250&in_page_id=1770
Chris Russell
Fri Aug 25 2006, 03:45PM
Chris Russell ... not Russel!
wrote ...
a residual current of at least 5,000 volts would have still been running through the cables
Nice. Must have been connected to one of those power plants that generate 50 megawatts per year.
Alex
Fri Aug 25 2006, 03:51PM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
Wow. He should go buy a lottery ticket, because he's both lucky and stupid.
Dr. Drone
Fri Aug 25 2006, 07:07PM
shades
Hazmatt_(The Underdog)
Fri Aug 25 2006, 08:59PM
I would write him a citation and have him come to a court date. Just try and explain playing on high voltage lines to a judge.
Fri Aug 25 2006, 10:53PM
It looks (though I could be wrong, legal disclaimer!) like he's swinging on the return current conductor they use for keeping ground currents out of phone lines and the like. It's bonded to the rails about every quarter mile and more or less at ground potential. So he's either not so stupid, or doubly lucky, to grab hold of the only wire up there that doesn't have high voltage on it.
Now if he had been swinging on one of the actual 25kV trolley wires, then I'd be impressed. Assuming he never got fried with 25kV at a few hundred amps by trying to climb onto the wire from a grounded bridge, he'd probably be fine until he got hit by the London to Glasgow Virgin Express at 125mph tongue
Alex
Sat Aug 26 2006, 12:27AM
Maybe if he was cooked he wouldn't splatter so badly.
dan
Sat Aug 26 2006, 05:19AM
dan Registered Member #223 Joined: Mon Feb 20 2006, 06:42PM
Well even if the line was active as long as you don't go near a grounded object you would be fine. From what I know when hydro workers are working on the power lines they tie them selves to the line potential. I theory if you jumped onto the line and jumped off without getting too close to ground you should be ok. I still wouldn't try it though or advise someone else to try it.
Alex
Sat Aug 26 2006, 05:51AM
You need to be brought up to potential though, and with the vast amount of current available, I would imagine that could happen rather violently.
Bored Chemist
Sat Aug 26 2006, 09:30AM
From the look of that picture he is at a much bigger risk from falling and hurting himself than from the electricity.
The charge needed to bring an isolated person up to a few tens of KV is trivial.
What I'm much more concerned about is that cable might be at 5KV even though the power is off.
