  • Guests: 38
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
IGBT driver
StormInABottle
Mon Mar 11 2013, 07:11PM Print
StormInABottle Registered Member #9252 Joined: Fri Jan 04 2013, 06:27AM
IXGX120N60B
I want to build a flyback driver to use 220 volt ac. Rectify or not. And be a high power one. make long arcs like zvs. Just a classic push pull driver. But most igbt full bridges i see on the internet. make some small tiny arcs Or atleast tell me how can i put an igbt instead of a mosfet on my zvs just replace drain with collector and and the source for the emitter. Or should i change values of some other stuff?
StormInABottle
Tue Mar 12 2013, 06:16PM
Why ain't no one replying? Searching google did not give me any results
Platinum
Mon Mar 18 2013, 09:33PM
Mon Mar 18 2013, 09:54PM
have a look around the forum, i made a post recently about my pcb for one, pity no-one checked out it against the schematic, but here: Link2
StormInABottle
Tue Mar 19 2013, 01:37PM
That uses mosfets.. OR is it great just to do a replacement? all components the same but put in igbts and draw a 4kw+ XD?
Daedronus
Tue Mar 19 2013, 03:31PM
From the drive point of view igbts are similar to mosfets.
Of course gate capacitance differed from model to model, but the same is true for different mosfets.
StormInABottle
Tue Mar 19 2013, 08:25PM
So yeah? They will work ?? also _=|(:3)-|--{__ I like your Link2 pll Tesla coil. IT is really simple. And easy. Also i can make it one a single small pcb. But is there a full bridge version of the schematics. And what happens if i place igbts instead of mosfets? And is there is a problem if i replace the half bridge with a filtered fullwave bridge rectifier? how much power is your coil drawing? Thanks alot
Tue Mar 19 2013, 10:28PM
im not uzzors2k, i was just saying earlyer about my PCB layout for one of his circuits
StormInABottle
Wed Mar 20 2013, 05:01AM
XD :P. Sorry :P
Thu Mar 21 2013, 10:33AM
Just use a standard half (or full if you wish) bridge, either GDT-driven or with a bootstrap driver like the IR2153, but it tends to explode when the layout is bad. The power output of a bridge circuit is basically limited only by the transistors, in your case, practically ulimited for a TV transformer. cheesey
