  • Guests: 36
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Lab/workshop clearance of miscellaneous parts
Dr. Slack
Mon Feb 25 2013, 12:10PM Print
Capacitors - transformers - heatsinks - LEDs - switches - semiconductors - random stuff
It's time to get some space back, both in the shop and in the head (polyprojectitus is a terrible thing). I've trying shutting my eyes and throwing the stuff in the bin, but it doesn't work. It needs to go to a good home. Very little of it is new, which inhibits me from putting much of it on eBay.
I'll update the list below as I dig deeper into my stores, or as stuff goes. So check back here from time to time.
Make me an offer on anything, all or part lot. I'm more interested in seeing it go than getting top dollar for it. If you want photos or more information on anything, please ask
I have a lot of stuff that's not on the list yet. Drop me a PM if you can think of something that I may have that you want, you might just be lucky.
  • PFC/Motor run caps - 425/475v - made by Ducati
    These are as new, but I've written on some of the cases with felt-tip pen
    • 8uF - 2 off
    • 20uF - 10 off
    • 40uF - 3 off
    • 50uF - 1 off
  • 10000uF (10mF) 63v Electrolytic caps - 6 off
  • 120uF 350v photoflash caps - lots
  • 1uF 2kV+ Microwave Oven caps - 10 off
  • General low voltage mid range various electrolytics - lots
  • AD7705 - dual channel 16 bit ADC - uSOIC - £6 each from RS etc - 10 off
  • LM733 - differential video amplifier with pinstrap gain control - DIL - 9 off
  • TLV2217-33 - 500mA fixed 3.3 regulator - TO220 - lots
  • LT1086 - 1.5A adjustable regulator - DD pak - 9 off
  • D43256C-12L - 32kx8 static RAM - 28 pin 0.6" DIL - unused - 30 off
  • SUP60N06-18 - 60V 60A TO220 FET - lots
  • MAV-11 RF amplifier - 12 off
    +12dB gain DC to 1GHz, usable to 2GHz or so, +18dBm out, 50ohm, cascadable, data available
  • Laptop power supplies - 15v 3A and 19v 3A - several
  • Wall wart power supplies - too many to list
  • Small DC flyback for TV - 2 off
  • FX2242 ferrite transformers - lots
  • 12v 1 watt SES bulbs - base can be soldered to - about 75
  • White 5mm LEDs - lots
  • Disposable camera flash boards - lots
  • XLR 5 pin latching connectors
    • Panel mount male - 2 off
    • Free cable female - 3 off
  • DPDT (double pole double throw) push switch - lots
    momentary operation, 1/4" panel mount, round black screw-on cap
    rated 115V 5A, but will be usable for 240V at lower current
  • Microswitches - standard and miniature sizes - lots
  • Single core 4mm2 (56x0.3) cable - various colours - a lot new on reels
  • Drill grinding guide
Fri Mar 01 2013, 06:33PM
Can you post some pictures of your larger transformers, ferrites and heatsinks please, id be interested in them.
Dr. Slack
Sun Mar 03 2013, 12:49PM
This is the heatsinks, the TO3 device gives the scale.
Others to come as I find them.
1362314955 72 FT151108 Heatsinks Cropped
back of the bright heatsinks
0006
Sun Mar 03 2013, 01:24PM
im interested in the back 2 silver heatsinks, could you put them aside for me as i am interested in other stuff as well. Thanks!
