  • Guests: 28
Hanzie (31)
badger (52)
h3X (40)
01/12 RoV IW3IPD (63)
Need suggestions for building a simple device to do the following.....
Vlad
Sat Feb 23 2013, 02:56PM Print
Vlad Registered Member #9711 Joined: Sat Jan 19 2013, 03:27PM
A friend has a solid lead 1/4" thick container about 24" L x 12" W x 12" H he wants to move onto his indoor 4 foot high shelf from a work area outdoors where the container is kept now at ground level. Since the container weighs close to 200 lbs, I'm wondering if it might be possible to build or find a simple device to move this from his outdoor location on the ground to the indoor location on the shelf. The distance moved would be about 50 feet in all and there is one 8" foundation step into the dwelling, then of course the 4 foot height increase for the shelf. At first I thought maybe there was an "appliance hand truck" that would do the job as I thought they might have the ability to crank the elevation of objects attached to them, but I don't think this is the case. Any suggestions would be appreciated. Thank you! Vlad
Sat Feb 23 2013, 04:12PM
thats 90Kg, im sure 2 people or mabye 3 could lift that with ease.
Vlad
Sat Feb 23 2013, 05:07PM
Friend lives in a remote area and is isolated, so doesn't have neighbors readily available. There should be something that can be built out of wood or even rent something, although he wants to be able to move the container around on occasion.
Sat Feb 23 2013, 05:46PM
some wood, pullys and wheels should do it then... Link2
Sat Feb 23 2013, 06:20PM
I would normall suggest an engine hoist (ex Link2 ) but it would weigh as much as box does...
I don't think many commercial tools would work for the job, because like others have mentioned it is light enough to just pick it up and move it. If he would have to drive into town to get the materials to build the hoist, why not just drive into town and pick up someone that can help lift it?
Vlad
Sun Feb 24 2013, 02:19AM
One thing that was overlooked and spotted at the auto shop today was a transmission lift. This has a securing strap that will easily fit around the box and will lift it up to 2 feet, which is what is desired. And it will handle up to 450 lbs. On sale at $32 US, this was a no brainer. Problem solved for my buddy. Thanks again for the replies.
Physics Junkie
Sun Feb 24 2013, 03:07AM
Physics Junkie Registered Member #7267 Joined: Tue Oct 16 2012, 12:16AM
muscle milk!
