  • Guests: 30
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Inductor number codes
Alex M
Thu Feb 21 2013, 07:43PM Print
After reading Link2 on how to read the codes on inductors I am still having some trouble trying to read the values of a few inductors I have.
For example this one reads "2727D8", is that 272x7=1904uH(?), or have I got that wrong.
1361475405 3943 FT0 Dsc 3039
And this one, I have no idea how to read the inductance value for this one.
1361475615 3943 FT0 Dsc 3035
I feel like I am missing something obvious so any help would be appreciated!
Thanks.
Thu Feb 21 2013, 08:50PM
That value looks a huge amount more then the windings would suggest, mabye try getting a Inductance meter?
Alex M
Thu Feb 21 2013, 09:25PM
__=|(:3)-|--{__ wrote ...
Thanks, I was thinking it looks a bit too large a value for the size.
What about the second one, how would one read that? It looks more like a product number than a value to me.
I looked at inductance meters but they look quite expense for what they are, does any one know of any cheaper alternative inductance meters?
Adrenaline
Thu Feb 21 2013, 09:35PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
The first one should be 2.7mH (27 * 10^2). I don't know what the fourth number is for. Seems reasonable depending on size Datasheet
The second one doesn't align with any standard codes except for 151 = 150uH.
For measuring the inductance if you have a function generator and 'scope you can use a known capacitor and measure the resonant frequency of the combination then back calculate the inductance.
Alex M
Sat Feb 23 2013, 04:07AM
Adrenaline wrote ...
Thankyou so much! cheesey
Ash Small
Sat Feb 23 2013, 08:37AM
Yes, I generally use a 100 Ohm resistor on the output of the signal generator for protection, with the inductor and 'known capacitor' in parallel, with the 'scope in parallel with the inductor and capacitor.
Just turn up the frequency on the sig. gen untill the 'scope reads the highest amplitude, then calculate using an online LC calculator.
Alex M
Mon Feb 25 2013, 05:28AM
Ash Small wrote ...
Since I do not have a function generator, would I just be able to use a square wave generating IC with a fixed duty cycle (50%) and adjustable frequency?
I am guessing it should work ok, but just want to be sure.
