  • Guests: 48
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Nixie clock prototype boards for sale, cheap!
magnet18
Sat Feb 16 2013, 06:33AM Print
Hey guys, long time no post!
This is the perfect opportunity for anyone who's waned a nixie clock but not wanted to do much work
I recently ordered a prototype batch of nixie clock circuit boards, unfortunately they came with some errors (my fault, bad design)
so, I can't actually sell them, but i know you guys on here have no problem doing a little soldering work, so I'd be willing to sell the kits to you for as cheap as i can, to the point where i'm making no money just to break even.
$29 for just the boards, supply your own parts (basically just tubes, and some resistors and transistors are all you wouldn't have laying around)
$99 for an entire kit
+shipping from Indiana
it would come with full instructions, including instructions on the flaws and how to fix them
the only large problem is that the tube pinout is reversed, meaning that 0 shows 1, 9 shows 2, 8 shows 3, etcetera
this could easily be fixed by running the resistors for each transistor to a different transistor, which would look sloppy, but could easily be done on the bottom of the board where it would be unseen and would be pretty easy
also, the signal line from clock output of chip 5 to input of 6 is missing, again, a simple wire on the bottom of the board
one diode needs replaced with a jumper, easy peasy
the only other thing is you need to swap pins 5 and 3 on the 4013, which can easily be done from the bottom, again, not interfering with the function or look of the clock
Let me know if you're interested guys, i've got 4 to sell!
Thanks,
Rob
__________________
44 64
