  • Guests: 59
kirE (36)
Sparkie (48)
indheat lover (37)
11/22 Goodchild (34)
11/22 pauleddy (34)
11/23 Munkey (32)
Adjusting a PI metal detector?
hsieh
Mon Feb 11 2013, 08:35AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I found this metal detector schematic on the Internet and build it.But after I finished it I don't know how to make it work because I cannot read the text.
Link2,228431276.pdf
now it only makes an annoying sound when I power it up.When I set P1 to a certain point,the sound changes slightly when I put a screwdriver or pliers near the coil(less than 1 cm).
My coil has 30 turns and 14cm diameter.
I substitute BF245 with 2N3819.I know their pin out are different.I think I wire it properly.
Thanks
