  • Guests: 56
Help needed with flyback Tesla Coil
Njubster
Sun Feb 10 2013, 04:57PM Print
Njubster Registered Member #6857 Joined: Sat Sept 22 2012, 08:25AM
I finished with my exams and I decided to make a small SGTC, and of course, once it was finished it didn't work :) I mean, it did spit few sparks from time to time, but that's not what I want.
It is flyback driven, and I am using this schematic:
Table Top SGTC Schematic
This is my secondary:
064 Zps18f0c9a8
(It is not really large, this is not a real T-rex)
The wire is 0.2mm. I was too lazy to count turns, and I didn't have any counter, so I counted 50 turns, measured the height, and divided the final height (171mm) with it to estimate the number of turns, and it was 806T. DeepFriedNeon calculated that L=3749.219uH and C=2.577pF. The secondary form is 33mm in diameter.
I found a pot cover holder and used it as a top load. I didn't know how to calculate it's capacitance, so I estimated it to 3.933pF, which is the capacitance of a 5cm wide metal ball.
For capacitor, I used 4 8.2nF capacitors connected in series, giving 2nF at 8kV. I put 1W 10MOhm resistors across the caps.
Spark gap is made out of two screws, adjustable, nothing special.
For flyback I use 18V 3.57A laptop charger, and this is my driver:
Link2 . It gives about 5cm long arcs. I intend to build ZVS, but right now I can't.
I sticked a 1m long metal rod in the ground for secondary's ground, and made a primary from 5 turns of 1.5mm wire, and I was only able to draw sparks with a metal object. My heart is broken.
Now, my questions:
-Is this secondary OK for a small, flyback driven TC?
-Is estimating the top load capacitance the way I did it a big mistake?
-Are secondary's and top load's capacitance connected in parallel, or in series? Will the F(res) of the secondary be:
F(res)=1/(2*Pi*sqrt(L*(Csec+Ctop))) or F(res)=1/(2*Pi*sqrt(L*1/(1/Csec+1/Ctop)))
-About secondary's ground, because it is not a big coil, can I ground it to wall outlet's ground? Or maybe flyback's ground? Or should I stick to my metal rod?
-Are bleeder resistors a mistake with this schematic?
-And my biggest problem, winding the primary: With this schematic, with cap in parallel with primary, how do I calculate the number of turns needed? I want to make a helical coil with 8cm diameter, and I have 2.4mm enameled wire prepared for it.
ps: Sorry for my bad English
Ash Small
Sun Feb 10 2013, 05:27PM
Is the gap sparking continuously?
Do you have a DC flyback you could try? it would give higher voltage, but I'd protect the internal diode with a resistor on the output, quite a high value one.
The topload might benefit from adding a breakout point.
(Others may have better ideas. I built this circuit, but only used it for an HF TIG welder, where it arced under argon to metal, and needed much less power)
Njubster
Sun Feb 10 2013, 05:53PM
Yes, it does, but the interesting thing is, it starts by making a typical TC spark gap sound (RATATATATATATATATATA) but later, 10 secs or so, the spark becomes continuous, it doesn't break anymore. That happens every time.
Yes, I am using DC flyback, but no resistor at it's output. I will try the breakout point, but even with drawing arcs with metal object, the sparks aren't big. They are minimal.
ZakWolf
Mon Feb 11 2013, 06:56AM
Njubster wrote ...
Sounds like not enough capacitance or the spark needs to be blown to stop it from becomming continuous, try a small fan or many small gaps
