  • Guests: 45
VTTC questions
Sun Feb 03 2013, 08:38AM Print
Hi all.
I noticed something interesting in that box of components obtained wayback, what appears to be several PL500's.
The problem is that these aren't really high power, apparently they are 4KV at something like 200mA max.
Is there any way to series/parallel them to increase this or is it a lost cause?
Thanks!
-A
Sun Feb 03 2013, 01:46PM
Beam output pentodes like PL500 were designed to be as much like an on/off switch as was possible with thermionic technology.
The key figure in the data sheet is the anode dissipation design centre limit of 12 W, and screen dissipation limit of 5 W.
With Va max 7 kV, and Ik max 250 mA, the on periods in the duty cycle must be made very short indeed if the valve is not to be destroyed.
Under what the data sheet calls the 'worst probable conditions' the valve will function with an anode dissipation of up to 17 W, and screen grid dissipation of 6 W, which will no doubt shorten its life.
There is no reason you cannot connect these beam power pentodes in parallel at the low frequencies generally employed in Tesla coils, but I would suggest that you made every effort to keep wiring as short as possible, and put anti-parasitic chokes in all the grid and anode connections immediately at the valve bases and top caps. It would be good practice to check the whole thing out with an absorption wavemeter to detect parasitic oscillation (commonly in the VHF), and ensure that harmonics and other spurious emissions are below statutory limits.
Ash Small
Sun Feb 03 2013, 03:27PM
I've a PL500 somewhere (possibly from a box you sent me, Andre, by the way, any news on the next one yet smile ) and it sounds from your post, PM, that I may be able to use it in a project I have underway for switching a magnetron based ion source, depending on duty cycle.
I'd be interested in those PL500's if you decide not to use them, Andre.
Marko
Sun Feb 03 2013, 03:59PM
Hi guys
a while ago I used a pair of PL504's in a half bridge configuration much like mosfets to base drive a Tesla coil. Despite the tubes weren't at their best with emission I managed to get over 1kW throughput and no plate reddening at all; however I had to push the voltage upwards 5-6kV.
P6110001
P6110002
P6110009
I wrote an article about it on my site Link2
Mr.Black
Sun Feb 03 2013, 04:48PM
Mr.Black Registered Member #3960 Joined: Mon Jun 20 2011, 06:27AM
The PL504 really 1kw power output?
It sounds unbelievable!!!amazed
Sun Feb 03 2013, 10:05PM
Ash Small wrote ...
I don't know the ins and outs of your project, Mr Ash, but I suspect the old PL500 might be underpowered. How about another line output valve, PL509, which can dissipate up to 30W Link2 , or PL519 which can manage 45W? Link2 Four of them in parallel would be a sight to see! smile
Ash Small
Mon Feb 04 2013, 12:09AM
Proud Mary wrote ...
I'll only be running it @~20W max, but I'm not sure about pulse width/duty cycle yet.
Mon Feb 04 2013, 08:45AM
The problem with TV valves is that most were designed for transformerless series heater operation, so we find PL500 and PL504 needing a 27V/300mA heater supply, and PL509 and PL519 needing 40V/300 mA. Clearly, this is a big turn off, but the plus side is that series heater valves tend to be cheaper. than comparable 6.3V heater types.
Tue Feb 05 2013, 09:59PM
These tubes have a really low internal resistance. If used in continuous wave mode, going over 600-900V on the plates doesn't have any benefit, up to around 1200V can be used when running in pulsed mode, more than 1500V DC can result in flashover, especially in older tubes.
I have found that these tubes easily take pulsed cathode currents of over 0.5A if the average current is kept below 0.25A, this means some 600W peak input per tube at 1.2kV. The plate efficency of class-C oscillators built with these tubes can be pretty high (probably over 80% in some cases), so the average input power can be several times the plate dissipation without overpowering the tubes.
As to the paralelling: Direct paralelling of tubes usually results in parasitic oscillations, put 220 ohm resistor in series with control grid of each tube to stop the oscillations.
NOTE: These data are based on short-term testing, the tubes may have decreased lifetime but in a Tesla coil it usually doesn't matter.
