  • Guests: 44
Zvs driver Questions. lots of them
StormInABottle
Thu Jan 31 2013, 04:10PM Print
StormInABottle Registered Member #9252 Joined: Fri Jan 04 2013, 06:27AM
First
The mosfets the shop has are IRF640N i bought 4. In hopes of paralleling them. One is capable of 200 volts at 18 amps. So if i parallel 2 togeather. What are the specs of the final product
The power supply for the zvs is a 200 watts 36 volts ac transformer. Spits out 50-40 volts after rectification..
Also should the zenners be 15 or 12 volts. I have booth
Would the fr607 diodes work..
And people say the ZVS is all about inductors and capacitors
So for the inductor. I have a spare old flyback transformer's core.. How much turns of wire should i put on that core to get a nice higher voltage not higher current zvs driver..
And... I could not find mmc or mkp types of capacitors.. So i bought ceramic.. IS there anything i can do to make the ceramic things act like mmc or mkp..
Also... For a dual flyback zvs...
Should i like. Make 4+4 turns in each of the flybacks then parallel those
Or 4 on one. and 4 on the other. And series them. Alsooo. I am able to buy the EXACTLY 2 same flybacks. The same model etc...
The model is a large nice flyback that gives spectacular results. :)
Also i can go NAUGHTY MODE. And buy another transformer like the one i have for some 72 volts in or something
