  • Guests: 99
01/12 RoV IW3IPD (63)
A new transistor
Adam Munich
Thu Jan 31 2013, 03:18PM Print
So it seems like we now have large magnetoresistance-based, current mode transistors. (Logic elements, to be truthful)
The paper> Link2
I have my doubts on how useful this might be though; seeing as something like this is likely to be as power hungry as an FPGA...
Pinky's Brain
Thu Jan 31 2013, 08:24PM
Firefox just says it downloads the file and then gives me zip ... IE9 just gives errors ... Mega really really wants you to use Chrome doesn't it?
Thu Jan 31 2013, 08:49PM
Magnetoresistance?! Seriously?
I always thought that it was far too slow to be used in this way, however many thousands of GMR elements on a little slab of silicon might be a lot faster and better isolated than a conventional IGBT or MOSFET.
testtest
Fri Feb 01 2013, 12:58AM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
Conundrum wrote ...
I was under the impression that new generation hard drives used it because of low power and high speed?
Sat Feb 02 2013, 11:43AM
They should rather focus on the SiC transistors, AFAIK there are still just the same FETs by CREE and they are still just as expensive. I know there are SiC BJTs but not in general production. It would be quite interesting I think to have an IGBT with nanosecond switching speeds...
Adam Munich
Sat Feb 02 2013, 12:53PM
Sic only has advantages in high power applications as far as I'm aware.
On that note Link2
Ash Small
Sat Feb 02 2013, 02:52PM
Have you seen what they are charging for 'samples' of SiC's?
High efficiency 15 A / 57 mΩ, FSICBH057A120 - Cost $ 49.00 USD/Device
High efficiency 50 A / 17 mΩ, FSICBH017A120 - Cost $210.00 USD/Device
Adam Munich
Sat Feb 02 2013, 03:14PM
CREE wants almost $500 for similar parts!
Give it a year and it'll be $10 like everything else.
Sat Feb 02 2013, 10:13PM
At that price it would be more efficient to make your own...
-A
Sun Feb 03 2013, 05:40PM
It has already been over a year, and the prices are still just as extreme. I think when those FETs would enter the market, the standard parts would soon become obsolete and all those big companies don't want that to happen, so they probably do all they can to keep SiC away from common availability and price.
