  • Guests: 91
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
full bridge 6kW inverter! high voltage big arcs
zilipoper
Sat Jan 26 2013, 01:30AM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
Hi Guys this is my first bridge inverter what I have gathered cheesey
fact that he is not resonant current in the primary winding reaches 210A
the switches I used FGH60N60SMD keep in primary winding current 210а and does not explode amazed
wires going to the electrolytic capacitor, heats up and melts cheesey cheesey
later I replaced the switches on skm150gal12t4 that would raise the current in the primary circuit to 300-400A! angry
the power consumption of the network at the maximum arc is 6 kW
MMC in the primary circuit I don't use the photo
1359163624 4152 FT0 3hjrl4up5ry
1359163624 4152 FT0 Cskuwx2pfq4
1359163624 4152 FT0 80ttfg0cuam
1359163624 4152 FT0 Sam 0570
Ya
1359163684 4152 FT0 G6f6wkndugq
1359163684 4152 FT0 Xfosp Gak0y
1359163684 4152 FT0 Hc2nkisojp4
1359163684 4152 FT0 Hnnzczmewqu
Sat Jan 26 2013, 06:20AM
Heh, looks good fun! smile
GrantX
Sat Jan 26 2013, 08:11AM
Wow, that's an impressive output, almost like a solid state MOT stack.
I agree, looks like a lot of fun!
Tony Matt
Sat Jan 26 2013, 08:39PM
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
Zillipoper :
Why you do not post the complete schematic and material specificationS ??
Cheers
zilipoper
Sat Jan 26 2013, 11:00PM
later everything will be;)
