  • Guests: 33
Fullbridge inverter and homemade flyback picking up radio transmissions
cjanik
Wed Jan 16 2013, 03:32AM Print
cjanik Registered Member #4460 Joined: Sat Apr 07 2012, 08:31AM
I recently built a a TL494 driver a la scopeboy's site and wound a flyback with 1246 primary turns 12 primary turns. When I have it on it picks up some type of radio broadcast which is audible in the arc.
How would the flyback driver be able to demodulate an AM or FM signal like that?
Video here:
http://www.youtube.com/watch?v=YRwzQTd0L0E
Wed Jan 16 2013, 10:19AM
Haha, do you live near a powerful radio or TV transmitter? cheesey I think putting the driver in a shielded metal case would work, also make sure you have decoupling caps everywhere and as close to the IC as possible.
I once had an audio amplifier with an IC, which would play a radio station when I touched one of the electrolytic capacitors.
Wed Jan 16 2013, 12:14PM
It is usually the other way around, the flyback driver interferes with all your radio equipment. cheesey
Wed Jan 16 2013, 03:08PM
The FCC has turned the tables on that whole "must accept interference."
Thu Jan 17 2013, 01:54AM
Are you able to detect AM and FM or just AM?
im suspicious it must be AM, if it could demodulate a FM signal down , that would be even more worthy of investigation. remember AM recievers are the simplest, even a coin, razor and crystal can be used for those captured in POW camps.
a modded russian missle using AM/FM slope detection may have been the method used to down the first F-117 in the late 90's.
Thu Jan 17 2013, 02:06AM
I agree it is more then likely AM. I wonder if the circuit that drives the fullbridge is being interrupted by the interference causing the switching elements to not turn on fully or at all depending on the strength of the signal.
Newton Brawn
Thu Jan 17 2013, 10:38PM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
ya...
Long time ago the shaks in Rio de Janeiro that ae locate close to the AM brodcast station use long wire antena to absorve the energy, supplying the neon bulbs.. Free energy !
Fri Jan 18 2013, 03:11AM
Newton Brawn wrote ...
yes, but the energy came from someone elses pocket.
