  • Guests: 33
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Some guy has HV fun with 244 9V batteries
Tetris
Sat Jan 12 2013, 05:08PM Print
Is this anyone from 4HV?
Ash Small
Sat Jan 12 2013, 07:48PM
I'm not sure if it is, but it's a big co-incidence if it isn't.
testtest
Sat Jan 12 2013, 10:14PM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
Keep in mind that there are no current limiter here. A 9V battery can source a lot of current if shorted. Not a big deal at 9V but more so at lethal voltages.
Second point would be if someone used lithium batteries or such. The resulting fire would be interesting.
Definitively not a "try at home" stunt....
Remember someone at work that put two 9V batteries in his pocket. They somehow touched together and shorted.
Nasty burn on his leg from the heat and acids. Still has the scar last time we were at the beach.
Sun Jan 13 2013, 02:43AM
richnormand wrote ...
yeah "a try this at some other dopes house" stunt...
i wonder if the "crackling" sounds were his internal shorts developing? A 160 degree F, 9V is pretty hot.
Tetris
Sun Jan 13 2013, 09:50PM
Conundrum, I remember an old post too. That's what made me wonder if he's from 4HV. I remember someone posting about "What to do with 240 batteries?" Or was it capacitors...
Avalanche
Sun Jan 13 2013, 11:10PM
I don't like high voltage stacks of batteries, because they're difficult to turn off if something goes wrong! Any mechanical switch or fuse on that stack would just draw an arc if it tried to break a fault current!
Here's a battery related emergency disconnect I rigged up at work for a one-off test a while ago cheesey
1358118602 103 FT148963 Dsc00456
Mon Jan 14 2013, 06:51PM
This should go on Link2
-A
Ash Small
Mon Jan 14 2013, 08:46PM
Ash Small wrote ...
Conundrum wrote ...
-A
So it wasn't you, then, Andre?
Tetris
Wed Jan 16 2013, 09:57PM
Conundrum wrote ...
-A
You're right. I should submit the link xD
