  • Guests: 52
kywalda (63)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
PCB related chemical concentration calculator.
Daedronus
Fri Jan 11 2013, 11:29AM Print
Since right now I'm fooling around trying to make PCBs I did this little calculator for a few things I need, someone else might find it useful.
So far I added the values for copper plating, dry negative mask developers, POSITIV 20 developer, sodium persulfate based pcb etching.
the fine print: if you destroy your precious pcb or burn down your house using this, I'm sorry, but I assume no responsibility.
Physics Junkie
Fri Jan 11 2013, 06:53PM
Physics Junkie Registered Member #7267 Joined: Tue Oct 16 2012, 12:16AM
The link is blocked. It says access must be requested.. But thanks for sharing, im interested to see the chart. I just started my very first pcb etching yesterday for a TC controller.
EDIT: I was able to access the link by logging into a different google account. Sorry for confusion. And thanks for posting the chart smile
Daedronus
Sat Jan 12 2013, 01:41AM
Strange, it is definitely set to public view.
You will probably have to make a copy to change values.
