  • Guests: 40
stacking coils together
first  2 3 4 5
Wed Jan 09 2013, 11:14PM
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
any idea how to find out if the core is saturating at 20KV? or how can I find out how much the core can handle? (I mean formulas)
just curiosity cause I had used a smaller core with smaller coil and add them up together same way as here and I can get to 14KV each coil can output 7KV so it adds up.
so I'm trying to find out why this would not add up, I did try putting a diode in between and the KV went up to 20KV with the 2 coils in series. but without the diode the output is 5KV.
Thu Jan 10 2013, 12:00AM
Maybe you have excessive volt-seconds product in the primary and it is saturating the core.
Thu Jan 10 2013, 12:07AM
Andre wrote ...
Maybe measure how much current the primary is drawing?
Do you have a datasheet for the cores?....You can't really tell how hot they are if they are under oil.
Antonio
Thu Jan 10 2013, 12:55AM
By the picture it looks as everything is under oil. Ok, as the insulation doesn't look adequate for 20 kV in air. To reach 20 kV is quite easy with minimum care with insulation. But 40 kV is a different issue. Is the voltage divider under oil too? Is it really working correctly with high voltage? Corona at the HV end and leakage through support structures, and even the oil, may cause false measurements. As already mentioned the 500 M load may be excessive for the system. 25 kHz in so large coils may also result in large losses due to leakage inductances and parasitic capacitances, but if one coil alone works this is probably ok. Note that the perforated boards in the assembly may not have enough resistance and may be loading the system.
Carl Pugh
Thu Jan 10 2013, 04:34AM
Carl Pugh Registered Member #1064 Joined: Tue Oct 16 2007, 05:04PM
Try spreading the primary over the full length of the core.
Thu Jan 10 2013, 04:42PM
Carl Pugh wrote ...
I did try that with a different core, and I got the same results,
ok Antonio, I will build new coils and try with more resistant, that's the only thing I have not tried, the coils I had they both burn already,
Shrad
Fri Jan 11 2013, 10:06AM
which oil type is this?
have you boiled it t oget rid of the water?
Electra
Sun Jan 13 2013, 12:26AM
I think the problem is your turns ratio
If your turns Ratio is 3200/30 = 106.7
24v x 106.7 = 2560.8v per secondary
5kv total would be about what you would expect.
The higher peek voltage you were reading could possibly be down to switching spikes during the off time.
Your 500M ohm resistor even at 40kv would just consume 3.2W
if your transformer and driver is capable of more than that it shouldn’t be a problem for reading dc voltage.
Tony Matt
Sun Jan 13 2013, 02:17AM
Andre',
Electra kill the question....
Yes, the tranformer can not provide more than 2560 v ac per secondary windind
The primary has 30 turns, and receive 24V. So the voltage/turn ratio is 24/30 = 0.8V/t
S0ooo the voltage in each secondary will be o.8 x 3200 =2560V ....
Disclose the cross section of the core.
What is switching freqwuency ?
The total number of turns in each coil?
How many turns in each layer?
How many layers on each coil?
What material and thichness of insulation between layers ?
HOW IS THE INSULATION BETWEEN THE COIL AND CORE ?
Pictures taken at dark room show corona ??
Regards
Antonio
Sun Jan 13 2013, 01:30PM
Quite obvious question that nobody saw before. Could be a flyback power supply. As the driving circuit was not mentioned, all the thread is just guesswork...
first  2 3 4 5
