  • Guests: 59
Evgenij (60)
Our Finest Hour (64)
Patrick (44)
01/26 oucivileng (39)
01/27 muller (38)
01/27 Dr. Mario (38)
Help with L200, measuring Output Current
tobias
Sun Jan 06 2013, 01:26AM Print
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
Hi
I am working on a PSU using the L200 to vary output voltage and limit the current. I want to be able to measure Output Current.
A series resistor at the output would do it, but I am wondering if the Current Limiting resistor R3 between pins 5 and 2 on the L200 could be of some use (see picture 7).
Does anyone knows how this resistor is used by the L200 to limit the current?
Datasheet states voltage between pins 5 and 2 is 0,45 V typ.
Would the IC trigger current limiting when voltage at the R3 reaches this threshold, being V2-3 linear related to Output Current?
Or at any given time/output the drop at R3 will always be 0,45 V?
Happy new year to all!
Sun Jan 06 2013, 01:55PM
Is there some reason why you can't just put an ammeter in the output line? That's what I'd do.
tobias
Sun Jan 06 2013, 02:06PM
I want to record both the Voltage and the Current values using an uC.
Sun Jan 06 2013, 03:51PM
tobias wrote ...
Ah yes, my methods are a bit too basic for that! smile
tobias
Mon Jan 07 2013, 03:32AM
I hook up a gig to measure Vin, Vout, Iout and the voltage across the 'current limiting resistor V2-5'.
With limit set at ~0,5A, V2-5 remained 0.0014V until Vout dropped limiting the current. At this point I measured 0.42V.
While still curious to find how the limiting works, I will just add a series burden resistor to the output and measure current from there!
