  • Guests: 52
Small 30KV transformer
Linas
Sun Jan 06 2013, 12:07AM Print
Hello. I have unfinished my CBCT scanner, so after exam i want to try rebuild HV part.
I have oil cooled 120KV tube, and i need few kw of power to get high energy x-ray.
Idea is to use two 30KV transformers, and voltage doubler like with tesla coil, two diode and two capacitors.
I have 1nF 80Kv High quality caps, and 120Kv BYV26E avalanche diodes (100 in series )
so i should get +-60KV from my multiplier to respect of ground for safety, and also i have to make simple 6V transformer with same amount of insulation for filament heating.
Idea shown in picture:
Blue is windings
Red is Ferrite core
Green is plexy glass, made from 1mm and 2mm sheets, and all void space would be willed with epoxy.
1357427388 1143 FT148662 A
I really need bigger U shape , but i have 6mm of plexy glass for 30Kv, and 4mm for 3.3kV in between windings, where epoxy should be, again, no problem.And quite low parasitic capacitance, witch is good smile
U cores:
And also, can any one tell any good about 3C80 material, can it hold 1Kw per transformer ? (150Vac, 10T, 40-100Khz)
(i really don't know how to deal with power and other calculations frown )
