  • Guests: 101
01/12 RoV IW3IPD (63)
Kapton Insulation
Linas
Sat Jan 05 2013, 07:25PM Print
Hello,
does any one try to use kapton tape or film for Flyback transformer insulation ?
I need to make two transformers with 30KV output capability, and started to search for insulation.
Idea is to use U core, , wind secondary dipped in epoxy, and use kapton tape in between layers.
U cores:
Or maybe some one know where to buy larger U shaped cores, since not much winding space left...
nixie
Sat Jan 05 2013, 08:21PM
nixie Registered Member #3908 Joined: Tue May 24 2011, 09:40PM
Good question. I've learned some lessons with this already.
I have used 1mil Kapton successfully, with P221 acrylic adhesive for this exact task.
Beware, there are two adhesive choices; acrylic and silicone.
The silicone may affect and/or contaminate an epoxy encapsulation afterward. Often resulting in epoxy voids during catalyzation.
If you're potting, you'll have better success with the acrylic adhesive.
The manufacturer identification is: P221 for Acrylic based adhesive (permanent), and P222 Silicone based adhesive for high temp (500f) operation (removable).
Regards, Jeff
Linas
Sat Jan 05 2013, 11:12PM
i guess i will stick with plexyglass insulation.
Idea shown in picture:
Blue is windings
Red is Ferrite core
Green is plexy glass, made from 1mm and 2mm sheets, and all void space would be willed with epoxy.
1357427388 1143 FT148662 A
I really need bigger U shape , but i have 6mm of plexy glass for 30Kv, and 4mm for 3.3kV in between windings, where epoxy should be, again, no problem.And quite low parasitic capacitance, witch is good smile
Thu Jan 10 2013, 11:47PM
how much insulation do you have between the primary and high side secondary? ill you vacuum draw the epoxy in?
TSC is a good supplier.
Ash Small
Fri Jan 11 2013, 12:27AM
You can buy bigger cores. You can also sandwich cores together. Another alternative that is popular with HV'ers is to arrange four sets of cores in a X shape, with the primary around the intersection, and secondaries mounted on the extremities. This creates a core with four times the power of one set and aids insulation on the secondaries, It also helps with reducing capacitance problems (I think). It also aids cooling.
EDIT: I'll add more details when I'm sober.
nixie
Fri Jan 11 2013, 01:45AM
Ash Small wrote ...
Bwah hah hah, I'm with ya. EDIT, sorry about my wasteful post smile
Regards, Jeff
Linas
Fri Jan 11 2013, 11:32AM
Patrick wrote ...
I have "special" copper wire, 10KV rated, it will be submersed in epoxy while i will wind it. i will have at least 4mm of Plexiglas to core, and another one 2mm for primary coil
so in short:
8mm of Plexiglas between first and last turn to with respect to core, and 6mm respect to primary.
and in between windings i should get 4mm of Plexiglas and 1mm of epoxy for 3.3KV
I guess i will leave ferrite core floating, or maybe use >1M resistor to ground, so it will not drift to far from zero.
Or even better idea, i will use two resistors like 100M in series in secondary, and connect core to middle voltage, so i will get 4mm of Plexiglas for 15KV for secondary, and 15KV for 3mm of 1capton+2Plexiglas for primary just will resistors be able to keep transformer ferrite core under that voltage ? confused
NO, i don't have equipment to do vacuum filling, i just going to heat epoxy, it will be like water, and fill it, best i can do in my mind.
Figures looks like right, with lot of place for error, but what i don't like that maybe i can't get enough voltage from transformer frown
Fri Jan 11 2013, 08:10PM
yeah i think if you cant reach 50um of vacuum, then "wet-winding" is next best...
