  • Guests: 72
Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
02/05 teslaguy (36)
Quick MOT question.
zippotix
Sun Dec 23 2012, 08:33PM Print
zippotix Registered Member #5208 Joined: Thu Jun 07 2012, 06:12PM
Hi, I was wondering if I could use a MOT PSU (currently 22 turns of 18AWG wire,230V) as a ballast for another MOT with secondary intact. If yes, how to do it?
Mon Dec 24 2012, 10:45AM
The best way to use a MOT as a ballast is to grind off the weld on the core, remove the I-part and reassemble with an air gap. Leave the secondary winding disconnected.
zippotix
Mon Dec 24 2012, 02:40PM
Thanks for reply Dr.DarkCurrent. I don't have the suitable tools to grind off the weld, I barely removed the secondary, these things are quite tough (are you Jmartis2?). I used a heating "coil" from a kettle, it works but it get's really hot. BTW, if I get it right, the kettle was rated at 2kW, so, 2kW/2100V=2100V@95mA, right?
EDIT: Merry Christmas everyone!
Alex M
Mon Dec 24 2012, 04:27PM
zippotix wrote ...
The kettle coil gets hot becuase its designed to be run underwater cheesey
You are on the right track with the wattage, however the actual power to the MOT may be slightly lower due to other looses.
Merry Christmas to you too!
Mon Dec 24 2012, 06:39PM
You can break the welds on a MOT core with a hacksaw. tongue
When using a MOT as a ballast I like to remove the secondary completely. It can be replaced with a primary from another MOT to get more inductance options.
Tue Dec 25 2012, 07:03AM
Steve Conner wrote ...
Yup, I've done that and it took only a minute or two. The thin kerf lets you retain some weld bead on each stack of laminations, so they don't fall apart.
If your objective is just to separate the copper from steel, a hammer and chisel can break the welds in a few seconds.
Tue Dec 25 2012, 11:11AM
BTW its 950mA not 95 tongue and yes I'm jmartis2 from youtube.
Harry
Tue Dec 25 2012, 01:05PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
I think 2100VAC is the open circuit voltage, it drops down under load because of something called secondary impedance (it's a bit like internal resistance in batteries). Assume it puts out 1000mA, so with a 2kW power out we get 2kV. Realistically it will be less as MOT's have very poor efficiency (~60%). Also with a 2kW ballast you have to take into account the power draw of the MOT (say 3kW?) as it has it's own impedance.
zippotix
Tue Dec 25 2012, 05:27PM
Yeah, I know this transformer is lossy and generally crap :). I will try to hack through the welds. Dr.DC, you helped me with the halogen flyback driver, remember :D? But do you mean 950mA output even with 2kW ballast? That would suck, I was hoping it would be somewhat safer to mess around with. I'm seriously careful with MOTs, even the noise it gives is malevolent.
Tue Dec 25 2012, 07:12PM
Well the current is the short circuit current. You would need to use a 200W ballast to drop it to 100mA, a light bulb could work.
