  • Guests: 52
OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
01/25 Patrick (44)
SMPS capacitor overheating from ripple
Carbon_Rod
Sat Dec 15 2012, 08:10AM Print
We decided to use one of those new 1.5F super-capacitors to stabilize a high-current low-voltage supply, but it seems to be running rather hot for the setup (<50kHz switching frequency).
Note that this has not exceeded the rated 80'C limits, but I am concerned its operational lifespan is going to be rather short. wink It was operating normally while not under load, and therefore unlikely its the cap itself that's damaged.
Anyone have experience with how well these new caps (EDLNF155B5R5C) tolerate ripple stress?
Cheers,
Rod
Sat Dec 15 2012, 09:43AM
I would think those supercaps would have higher ESR than proper low-ESR SMPS caps, even of much lower capacitances.
The output capacitors heat up because of ripple current. Assuming you use a forward converter, the ripple current is directly proportional to the output inductor value, at a given frequency. So you can try increasing the output inductance and make sure it does not saturate, or increase the frequency.
Sat Dec 15 2012, 11:22AM
They're designed for backup applications, not high current discharge. Either connect an ordinary low-ESR electrolytic across it, or fix your control loop so the converter is stable with a normal-sized output capacitor.
Mattski
Sun Dec 16 2012, 10:50PM
According to the datasheet your cap is rated for 1mA DC current and has a large series resistance: Link2 it's just not suited for a situation with large ripple current. I seem to recall that capacitor series resistance usually helps stability in SMPS's so that may be what's stabilizing your power supply rather than the capacitance.
Carbon_Rod
Mon Dec 17 2012, 10:21AM
I am rather disappointed a negligible 0.35v ripple caused these caps to cook.
Even with 50 ohm Z at 1kHz specs, the other normal caps on the bus should have at least reduced part stress within SOA.
frown ...package type "F" indeed...
Thanks Steve and Mattski,
Pinky's Brain
Mon Dec 17 2012, 10:36AM
Pinky&#039;s Brain Registered Member #2901 Joined: Thu Jun 03 2010, 01:25PM
0.7*0.35*1.5 ... if it could actually smooth out the voltage (which it can't, with it's internal resistance) you'd be running at 367 times over maximum rating, you should be elated you're not showered in exploded ultracap :)
Ash Small
Mon Dec 17 2012, 11:13AM
Now....If you parallelled enough of them up........... smile
johnf
Tue Dec 18 2012, 06:56PM
Super caps are not designed for smoothing applications. They are used for energy storage to back up real time clocks and data held in static ram.
Use proper low ESR caps these usually have a tall thin in diameter ratio to aid cooling and just like modern high power supplies use several in parallel
