  • Guests: 62
01/12 RoV IW3IPD (63)
Ignition coil driver
radioman
Thu Dec 13 2012, 11:02PM Print
radioman Registered Member #3026 Joined: Fri Jul 23 2010, 02:46PM
Hi, Everyone
I am trying to drive an ignition spark coil with a microswitch activated by an eccentric on my small DC motor shaft. The coil is getting about 12 volts pulsating DC. I have a 0.1 mf capacitor across the switch. However, the spark I'm getting is barely visible! In a car, the coil is driven by the points -- just an on-off switch. Are these ignition coils designed to operate at a certain frequency? Why doesn't my set-up work very well??
Thanks much!
John M.
Thu Dec 13 2012, 11:39PM
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
radioman wrote ...
Hi, Everyone
Thanks much!
John M.
I will think you dont have enough current, are you running this with a battery?
also if you runing with a battery check this site out Link2
it has a driver circuit.
Ash Small
Fri Dec 14 2012, 12:31AM
These coils are designed to operate at a certain frequency, or rather to have a maximum frequency.
What frequency are you driving it at?
For example, when Jaguar introduced their V12 engine, they had to have ignition coils designed to operate in excess of 5,000RPM X 12 (one spark per cylinder every second revolution) eg 30,000 per minute (I think, I've had a few drinks this evening, so check my maths) = 5kHz.
EDIT: The figure that is important here is the 'dwell angle'.....The spark gap (points) needs to be closed for a certain amount of time before the coil 're-generates'.
EDIT: Also, you need a condensor (capacitor) of the correct value for the coil to function effectively. I forget the typical values, though. It's a long time since I tuned engines (30 years).
radioman
Fri Dec 14 2012, 02:24PM
Thanks, Andre
I think you are right: I am using a laboratory, regulated power supply delivering a max of three amps! I plan to build the driver in the link you included. How can I power this driver to deliver six amps?? Would two lantern batteries do the trick?
Fri Dec 14 2012, 06:21PM
radioman wrote ...
Thanks, Andre
I think the power supply has enough current, is just you need the correct driver circuit. it should work with the batteries and the power supply once you build the driver, post a video when you get it runing I will love to see.
Sat Dec 22 2012, 09:42PM
3A is not sufficient to drive a standard automotive ignition coil. 7A is typical for standard coils in a 12V system.
1356211799 543 FT147961 Ig Coil Spark At 2a  7a
In the left frame we see a discharge across a 5mm gap with 7A pulsed primary current. The anemic effort on the right is the same gap
and coil with 2A pulses.
If you are new to all this, I would advise you not to use any power supply you can't afford to replace, as high voltage spikes can sometimes travel back up the line and ruin your PSU. A 12V car battery would be a good place to start, and will provide plenty enough current.
