  • Guests: 33
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Need a CHEAP thermal imaging camera...
Nicko
Thu Dec 13 2012, 03:58PM Print
I would like to make/DIY a cheap low res thermal imaging camera so I can monitor heat loss from my beehives during winter... indeed, it would help me tell is a colony was still alive without having to open the box (and release heat, possibly killing the bees in the process). "Schroedinger's Bees", perhaps smile
It therefore needs to be portable. Great accuracy is not required, nor, theoretically is colour, though that'd be nice.
I'm thinking webcam sensor with IR filter removed or similar, plus an Arduino or similar, plus an LCD. Oh, and battery powered for a reasonable amount of time. I'm completely happy with any amount of electronics or embedded control work (programming etc.)...
Rather than random ideas (many of which I've already researched), has any one got practical experience in this or know of a viable solution/approach?
Many thanks
Thu Dec 13 2012, 04:57PM
Have you looked into the new 16x4 element detectors?
I have not had a chance to play with it directly, but its a heck of a lot cheaper than the actual thermal cameras I have used.
As per removing the IR filter from a webcam, unless your bees are at several hundred degrees there will not be any light in the 1um range (limit of a silicon device), you need a sensor which is sensitive to mir or far IR for room temperature applications
Pinky's Brain
Thu Dec 13 2012, 07:44PM
Do you still need one of those deep IR lenses to image with those sensors or is a lens build in?
2Spoons
Thu Dec 13 2012, 08:57PM
This approach is really the only way to do thermal imaging on the cheap.
Forget silicon sensors : longest absorption wavelength for silicon is 1.1um ; thermal imaging operates in the 5um to 14um range.
Cheapest real thermal camera I've seen is about $3k.
Thu Dec 13 2012, 10:29PM
i think your making this too complicated.
is it possible to put several thermistors at the center of each hive, before its populated? then a ribbon cable and small circuit board with a switch so you can check multiple hives from a safe distance?
Pinky's Brain
Fri Dec 14 2012, 04:49AM
2Spoons wrote ...
That is remarkably accurate even without an imaging lens ... guess the sensor is directional enough on it's own.
Fri Dec 14 2012, 06:06AM
Pinky's Brain wrote ...
2Spoons wrote ...
when i saw that video, i was stunned, its really cool.
Nicko
Fri Dec 14 2012, 10:13AM
... wrote ...
That's a great find - its Apple-only at the moment - I'm Android-based, but it looks like it would easily do the job I need.
A project to keep an eye on...
EDIT: Its now on Kickstarter, and I've part funded it: http://www.kickstarter.com/projects/andyrawson/ir-blue-thermal-imaging-smartphone-accessory
