  • Guests: 35
buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
Induction heating - inline water heating
Chobrutsky
Mon Dec 10 2012, 04:21PM Print
Chobrutsky Registered Member #8448 Joined: Mon Dec 03 2012, 03:23AM
Hey all,
Some great threads here on IH, but none that seem to really address the following project.
I'm trying to make a hot water heater, i.e. for beverages so not like a shower or for a whole house. I'm thinking about using an arduino to output a variable PWM based on the water output temperature. I'm running into some trouble with the circuits/physics of the IH though, and looking for some expert help here.
I'm thinking about doing 10-100 turns of 105/40 litz wire around a .405" OD, .215" ID, black steel tube, lined with a 3/16" copper tube carrying water through it. The length of the heating tube could be up to a foot if required, but obviously less material would be better. I need to heat the water at a speed of about 0.07GPM from about 10C-100C.
What I'm really looking for is an inverter circuit that I can control with a PWM signal, and then maybe some advice on what sort of voltage/current/kHz requirements I should start experimenting with. Also, I'm hoping to run this from a convention US power outlet, if that makes a difference.
Thank you in advance, from the looks of it there is quite a bit of expertise here.
Mon Dec 10 2012, 04:26PM
The project at the end uses an Arduino. You can modify the code and add a temperature input to customize it for your project.
Chobrutsky
Mon Dec 10 2012, 04:57PM
I don't think that project is really quite along the same lines. He has quite a different set up which isn't exactly analagous. The code is not my issue. It's the hardware and circuitry. He has his wires wrapped parallel to what appears to be a cooling tube. I'm shooting to wrap the induction wire circuferentially around a long thin steel tube to heat it up very rapidly, then having that heat tranferrred to the copper tube inside carrying the water.
Thanks for the help!
Pinky's Brain
Mon Dec 10 2012, 07:31PM
Or you could use a transformer and just heat the copper pipe ... with a meter of 1/8 inch tube you would need around 1.5 kA RMS :) (You need around 2 kW.)
More serious, I'd personally try wrapping 1/8 inch tubing in teflon and then wrap a coil of nichrome wire around that. Feed it with rectified mains and a buck converter or straight PWM. So at 170V you need around 15 ohm of resistance, a 4 oz spool of 18 SWG nichrome wire will get you a little below that.
PS. grounding the copper tube of course for safety, also you need a thermal cut off of course.
lightlinked
Mon Dec 10 2012, 07:54PM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
is what you want a separate inverter drive, ie induction part its own thing, controlled by an arduino as a PID?
Wolfram
Mon Dec 10 2012, 11:04PM
What advantage will an induction heater have over a resistive heater in this application?
Why not just use simple phase angle control?
Chobrutsky
Mon Dec 10 2012, 11:38PM
lightlinked wrote ...
Yea that was the idea.
What do you all think about just using a single mosfet gated with a PWM from the arduino to produce a DC half-squarewave signal at like 100khz? I'm really not sure about how to go about estimating the heat I'll be getting out of this thing as a function of tube length and coils, other than just going for it and seeing what blows up first or melts.
I'm looking into the other suggestions posted to see what I can say about those...
Thanks again
lightlinked
Tue Dec 11 2012, 12:17AM
if you were doing a resonant tank could you do zero cross switching with the arduino pwming enable at a low freq? i guess it depends how you want to tune it. maybe since the load stays the same, ie isnt something random being heated you could set it with a scope and set the freq with the timer registers
Chobrutsky
Tue Dec 11 2012, 12:27AM
From what I've read about induction heating, since my "work piece" is so small (.405" OD) to heat it efficiently i need to be over 100khz. How low are you talking for low freq PWM? My thought was that the PID would cause the PWM to go faster (higher freq) to heat more, lower freq to heat less. Does that sound right to you?
Chobrutsky
Tue Dec 11 2012, 12:30AM
Pinky's Brain wrote ...
That's not a bad idea. Is there something better than teflon to bridge the two? Teflon, while it can withstand high heat, to my known has terrible conductive properties. Do you think that'd be a problem? Do you really think I'd need 50ft of nichrome to pull that off? I think I need about 1600W. But I'm not sure how that translates into nichrome length/current/power/etc.
