  • Guests: 37
Bert (78)
MRacerxdl (34)
Alebaba (33)
kawenlong (37)
PeterJP (49)
11/08 Bert (78)
11/08 MRacerxdl (34)
11/08 Alebaba (33)
How to strip and tin litz wire
2Spoons
Fri Dec 07 2012, 02:25AM Print
If your litz has the nice melty enamel that strips with an iron you can stop reading now. However if your litz has been made with high temp enamelled wire - the stuff that doesn't melt at soldering temps - here's a little trick for getting the enamel off 50 strands of 40AWG!
It seems that the polyimide insulation can be degraded by caustic soda. After a couple of tests just soaking in caustic soda solution for an hour or two I found that all you need to do is this:
Mix about 1 teaspoon of caustic soda (aka lye, sodium hydroxide) with 1 teaspoon of water - this make a very strong solution. Use a glass, ceramic or plastic container.
Hot concentrated caustic soda is nasty stuff: wear gloves and eye protection. Dispose of leftover solution by flushing down the drain with lots of water
Dip the end of the litz wire into the solution, bringing it out wet. Heat the wet end with a tinned soldering iron - it will sizzle and spit so keep face and hands away. Once dry dip again to get a another drop on the wire. Heat again - the wire will sizzle, go dry, then sizzle again as the polyimide reacts with the caustic soda. At this point you will find the enamel can be wiped off with the hot iron, leaving tinned wire behind (assuming you had a little solder on there).
I can't believe its this simple, but I've now done it several times to my home made litz and it works every time.
Fri Dec 07 2012, 04:15AM
ive had the very same problem , and will try this method.
But where did you get the lye? is it drain hair ball cleaner?
Dr. Slack
Fri Dec 07 2012, 08:15AM
Patrick wrote ...
It's drain *grease* cleaner - turns the grease into soap, probably be white crystals, but may be an aqueous solution, then it's lye.
If it's specifically for hair (and paper ) then it's more likely to be concentrated sulphuric, which oxidises organics, and will only be a thick liquid.
Both are strongly exothermic on solution, so the warnings may not distinguish them.
Pinky's Brain
Fri Dec 07 2012, 04:10PM
I wonder if you could add an ultrasonic transducer to a cheap solder pot.
teravolt
Fri Dec 07 2012, 05:09PM
I use a solder pot at work. maby you could find a used one on ebay. it takes about 30 secs
Fri Dec 07 2012, 06:12PM
This method is specifically for the 'high temperature' litz wire, for which a solder pot does not work.
So far the only method I have heard of for getting the insulation off is by using hot NaOH
Fri Dec 07 2012, 08:26PM
... wrote ...
i use a razor blade or a dremel with sanding drum, but its a pain.... and inconsistent.
teravolt
Sat Dec 08 2012, 02:33AM
depends on how hot your solder pot is the one at my work gets 1000F. If the wire is 26 awg or larger sand paper woks or a blade
Hazmatt_(The Underdog)
Sun Dec 09 2012, 12:38AM
If the wire is small enough, like 40 strands of 38 awg or so, what i do is just get a decent size ball of solder hanging off the tip of my iron and pass the wire in. The varnish will succomb sooner or later.
2Spoons
Sun Dec 09 2012, 02:34AM
The two problems with the thermal methods are: 1) it doesn't work with high temp magnet wire, and 2) 40AWG copper wire dissolves quite quickly in solder so you have to be quick with the soldering iron (or solder pot).
Similarly sanding or scraping 40AWG is very difficult to do without breakage.
The lye I used is sold as drain cleaner. We can't get the sulphuric acid drain cleaner OTC in New Zealand, only the lye type.
