  • Guests: 71
Cheap/used variac (variable transformer)?
Sun Dec 02 2012, 12:31AM
zrg wrote ...
No need for any special preparations with it, though. Can be used directly from wall socket to your curcuit.
Incorrect, expcially with the larger ones, when you turn on these variacs they have a huge inrush current that can trip a breaker and blow most fuses, you need a soft start circuit most of the time from what ive heard and experianced
Yanom
Sun Dec 02 2012, 02:42AM
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
__=|(:3)-|--{__ wrote ...
zrg wrote ...
ok, so it looks like i need a small isolation transformer then.
Should I just hook it up between the variac and the rectifier circuit? I'm only looking at small variacs that can be plugged into the wall and powered up just fine.
Sun Dec 02 2012, 10:15AM
Have a look here: Link2
Yanom
Sun Dec 02 2012, 04:06PM
ok, I found the page describing what I wanted to build:
http://www.coilgun.info/mark4/hv_adjustable.htm
There he uses a variac plugged into the wall to make a DC power supply. Near the bottom of the page he talks about how the variac does not provide "line isolation", which I figured I needed in case I accidentally shorted out my circuit. So I thought that I needed an isolation transformer in there somewhere, probably between the variac and the rectifier. His variac can draw up to 6A and he plugs it into the wall with no problems.
