  • Guests: 44
01/12 RoV IW3IPD (63)
Cheap DMMs and HV
Tue Nov 27 2012, 02:42AM Print
Out of curiosity I used my cheapo mastercraft DMM to try to measure the current from my van de graff generator. It measured 3uA and when I swapped the leads to make sure it wasn't biased one way or the other it read -3uA. How accurate do you guys think that reading really is?
It can light an LED dimly but without flicker from just the corona so it is supplying a reasonably steady charge to the sphere. I don't know how the meter actually makes its measurement so I don't know if a voltage drop of tens (or hundreds) of thousands of volts would cause it to give false reading. Does any one have any thoughts?
Tue Nov 27 2012, 11:23AM
If your DMM has a standard 10MΩ input impdance, then the voltage drop across it will be 30V when 3 μA are flowing.
With no corona losses and little leakage at 30V, 3μA - or 90 μW - sounds believable to me as a derivative of the coulomb seconds being delivered to the sphere by the belt.
Ash Small
Tue Nov 27 2012, 11:56AM
This is a very interesting thread after some of the recent discussions here regarding electrostatics.
I assume you have no return path, you are just 'charging the ball'.
How does this fit in with the requirement that 'Every circuit requires a return path'?
Tue Nov 27 2012, 12:12PM
The return path was ground for both measurements. As cheap as it is I wasn't ready to to start hitting it with 8 inch sparks.
Mary, wouldn't the impedance be a lot lower in the current measuring mode? (like ideally 0) I think I have a 10Mohm resistor around here some where from a TV, I might try running the VDG charge current through that and measuring the voltage drop to see if I get results in the same ball park as my original readings.
Tue Nov 27 2012, 12:48PM
Nik wrote ...
Oh yes, how daft of me! Yes, I'd expect the impedance on the current range to be somwhere between about 0.1Ω and perhaps 8Ω, depending on the make, model, and range setting.
If you short the sphere to Earth via 10MΩ, and measure the voltage across it with a 10MΩ input impedance voltmeter, you will see the voltage drop across 5MΩ, if there is enough output to get a reading.
Wed Nov 28 2012, 02:51AM
wow! proud mary really goofed that one!
he might be better off with a 200M resistor then measuring the curve as the current drops (several seconds if R is high enuff), then use some derivitive magic math to find it out with more useful aaccuracy... if that matters.
if its nearly constant DC (and charge accumulation is) then he can use a smaller 10-50 Mohm resitor to meaure the current via voltage, which might be better for not killing his meter...
Wed Nov 28 2012, 04:30AM
I reworked the upper part of my VDG tonight and effectively buggered it. I had a taboo upper roller outside of the sphere so I reworked it to the more conventional design. Since then the output has been pitiful. Once I get it running better I'll see about measuring the charging current using your (plural) suggestions.
Uspring
Wed Nov 28 2012, 11:21AM
Another way to get the charging current is to measure the rate at which it sparks. Put a small grounded sphere say 2cm away from the VDG top. It will spark then every time it has reached about 60kV. The capacitance of your VDG top is about the same in pF as its radius in cm. For example:
Your top radius is 10cm. Then its capacitance will be about 10pF. The time between sparks is then t=V*C/I = 60kV * 10pF / 3uA = 0.2s.
That's ballpark, but should give similar values to your DMM.
radiotech
Fri Nov 30 2012, 03:51AM
What model Mastercraft DMM do you have? Those meters are used everywhere in Canada,
simply because of the distributor, and the periodic deep discounts they have.
I use models 52-0052-2 and 052-0060-2 in classes here and have yet to have one ruined.
Fri Nov 30 2012, 05:19AM
radiotech wrote ...
as bad as students are on intruements of all types, 10kv is worse...
