  • Guests: 47
Sonic (59)
kamelryttarn (47)
11/30 arnsfelt (46)
11/30 jaysun92 (33)
12/02 Hax (40)
Large Quadrotor FPV.
1 2 3 4  last
Chris Cristini
Tue Nov 20 2012, 05:39PM Print
My Project idea is to make it with.
4 17x8 Props
4 410 kv Motors Link2
4 100A Electronic Speed Controllers that Come with the motors
1 KK2 Flight controller board Link2
And for Starters I am just going to use x2 12v 10 aH sla Batteries And this Cheap 4 Channel Transmitter and receiver Link2
I also need to use a Voltage Regulator For the KK2 Flight controller. My plan for the frame starts off with an old Glass Table frame.
I also have a question about thrust the motors Specs state that they can put out 6520g of thrust Can I multiply that by 4 to get accurate Lift Potential of 26080g about 57 LBS Minus the weight of the Craft. For starters this will Cost just Under $500 not bad for Something of this size.
I forgot to Mention the fact I can only find CCW props But i need CW and CCW to counter react Rotor mass.
I know the size and weight of this project will have a whole lot more mass than this video Link2 but do you think the KK2 will react the same for this.
And this O.T but cool Link2
I think PVC will do Better than a Steel Frame.
Killa-X
Tue Nov 20 2012, 08:46PM
Sounds like a nice build, hope to see great process, love FPV.
I can't answer your thrust question but what Ghz video transmitter do you plan on using? And what wattage? Assuming you plan to video fly this thing like I typically do :)
Chris Cristini
Tue Nov 20 2012, 11:56PM
Well I am Not sure about Video thing yet I am just building the Basics for now
I am Planning on Adding.
Gopro FPV system or I can try Wifi PTZ camera like this one Link2 and some sort of WIFI extender.
GPS system with the ability of control from your computer with Game pad Link2
And some other stuff I am still thinking of things I could do I am going to have to wait for Income tax return to start this Project. I am also going to build a cheap Mini PC with an 16" touch monitor and put it all in a nice Suit case for a ground Station.
How do you measure Speed of an air craft?
Wed Nov 21 2012, 01:35AM
copy cat !
i kid , ikid, its good to see another flyer on the forum, but i in the strongest possible terms warn you to reconsider your poor choice in radio...
Chris Cristini
Wed Nov 21 2012, 04:00AM
But I have a budget haha. I however would like one of these Link2 I am also working On a mock up PVC frame with Solid Works I know its kinda cheap looking but I have only worked on it for less than 10 Minutes so far
1
1
I have been Thinking this thing Using 24V @ 10 Ah is only going to stay off the ground for a few Minutes and large enough LiPo Batteries are going to cost a fortune if I want to use it for Surveillance or something useful I should scale it up a bit and use Four 30cc Trimmer engines and replace the Brush less motors with throttle servos and make it with a 3 or 4 gallon fuel tank each engine would have electric start and a tiny generator also should come up with an exhaust system that would have a manifold connecting all the engines and make it less noisy.
Wed Nov 21 2012, 11:01AM
I don't think SLA batteries are capable of lifting their own weight, you'll have to use Lipos.
Chris Cristini
Wed Nov 21 2012, 03:03PM
Well that is why I am trying to figure out if thrust can work as lift Because the motors can produce Potential of 26080g about 57 LBS of thrust and the 2 batteries are only 14 LBS together.
Wed Nov 21 2012, 03:08PM
Sure, but how much current does it take to produce that 6520g of thrust? I'm going to guess it corresponds to the "Burst Watts" spec of 2300W, which is about 100A at 24V. So your 4 motors all together will need 400A at 24V to make that 57lbs of thrust.
I doubt a cheap 12V, 10Ah SLA can provide even 100A for any length of time. You get "rapid discharge" ones intended for UPSs, these might give better results. But Lipos aren't really that expensive nowadays.
Chris Cristini
Wed Nov 21 2012, 03:43PM
Ok will my 15 2400Mah LiIon cells from laptop packs make a suitable pack if I use 6 in series for 22.2V and Another 6 in parallel to make 22.2V @ 4.8 Ah wont last long. But if the SLA Batteries Have a melt down it would be fun to watch. I will check out LiPo batteries again. My Lithium Ion Batteries are like these ones Link2
Wed Nov 21 2012, 04:02PM
No, laptop pack cells aren't designed for rapid discharge, you'll just destroy them.
To answer your original question, the thrust figure should be equivalent to lift.
1 2 3 4  last
