  • Guests: 57
Parallel IGBTs current sharing during switching transitions
Sat Nov 17 2012, 11:01PM Print
Hi,
do you think that identical IGBTs in parallel will share the current well even during switching transitions, so the total losses can be equally divided? Use individual gate resistors, or one for all parallel gates? In large bricks, there are more identical junctions in parallel without any resistors. Thanks for your thoughts. smile
axelro
Sun Nov 18 2012, 09:28PM
axelro Registered Member #3640 Joined: Sat Jan 22 2011, 12:16PM
There's a lot of material out there, perhaps search for 'Igbt parallel PDF'.
Given, Drsstc's switch at zero current, that should help. But then currents are typically beyond spec which does the opposite.
Chosing Igbt's with positive temp coefficient should also help.
I could imagine several parallel smalll Igbt's with rules adhered to and closely thermal coupled on one cooling block per leg comes close to using bricks, especially with fast modern Igbt's.
But haven't tried it yet myself, but plan to.
Mon Nov 19 2012, 10:23AM
Well, I'm most worried about the difference in plateau voltage of the parallel transistors. The one with the lowest plateau voltage starts turning off after all others have turned off and gets most of the turn-off losses...
The reason I'm asking about this is that individual transistors eg. in TO247 packages are a lot cheaper and switch a lot faster than a single brick. And also because I have more of the smaller transistors and wanted to use them in a bigger TC smile
Mon Nov 19 2012, 10:55AM
Nowadays we are leaning towards building multiple H-bridges, and forcing current sharing with ballast inductors or matching transformers.
If you can have 4-layer boards made, you could probably make an array of TO247 devices that outperforms a brick. Certainly the kinds of bricks that you can pick up cheaply on the surplus market.
The biggest problem when parallelling IGBTs is stray inductance between the emitters of the individual devices, and the gate driver's emitter connection. The reason is that the full collector current flows through this inductance, and the L*di/dt voltage due to this high current appears in series with the gate drive voltage, so its effect is amplified by the gain of the device. Therefore, a tiny inductance can have a huge effect.
If you can make this inductance very low, and the same for each device, then they'll run happily in parallel. Soft switching also helps by reducing the di/dt term in the L*di/dt equation.
I'd always use an individual gate resistor for each device. They prevent parasitic oscillations, damp ringing in the gate drive buswork, and I think they may work with the Miller effect to "ballast" differences in switching speeds.
Mon Nov 19 2012, 08:59PM
Good point Steve smile With only 2 transistors in parallel, connecting the rf bypass cap as well as the gate drive connection right in the middle between the 2 emitters might help.
Jrz126
Tue Nov 20 2012, 01:31PM
The dice in a big brick are probably better matched too. Same batch of wafers, maybe even screened before hand.
When using multiple TO-247 devices, you could get them from different ends of the distribution curve.
I have seen some bricks with series resistors for each die. There's 0805 smt resistors around the perimeter. http://imgur.com/7UNKC (This brick would have liked a little more cooling)
Here's one that isn't blown up. http://i.imgur.com/8sOBX.jpg Larger squares are the igbt's, the single wire in the center is the gate. The smaller rectangles are the diodes. Not sure what the diamond shaped component is in the front. It's connected between the gate and emitter. Maybe a TVS?
Ash Small
Tue Nov 20 2012, 02:41PM
• Twist or run on parallel tracks the gate lead and the gate return lead to minimize gate emitter loop
inductance.
• Ensure that the gate of the IGBT is looking into a stiff (voltage) source with as little impedance as
practical. This advice applies equally well to both paralleled and single device designs.
• Do not place Zener diodes or Transient Voltage Suppressors directly between gate and emitter. If over
voltage protection is required on the gate, place the Zener diodes on the driver side of the gate resistor(s).
• Do not place capacitors directly gate to emitter to control switching times, instead increase the gate
resistor. The capacitors may cause oscillations and slow down switching, which increases the dynamic
unbalance between devices.
]an-1045b.pdf[/file]
Bennem
Tue Nov 20 2012, 10:20PM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Ash Small wrote ...
eh?....don't understand why they printed this statement.
Ash Small
Wed Nov 21 2012, 01:26AM
Bennem wrote ...
Ash Small wrote ...
It puzzled me too. The only reason I can think of, and I've had a drink or three, is that the resistors will run cooler (resistance increases with temperature) but maybe someone else can come up with another reason?
Kizmo
Wed Nov 21 2012, 09:08AM
I think its because these TVS diodes and Zeners do clamp rather hard and it may lead into high frequency oscillations if there is nothing to eat the energy.
Actually i have seen quite a few commercial applications where gate protection is placed before final gate resistor :)
