  • Guests: 39
Tin whisker issue
Fri Nov 16 2012, 07:30PM Print
Hi, has anyone else run into tin whiskers forming within days?
This PS3 was working fine but stopped reading, turns out that there was an internal short between R and B anodes which appears to be classic whisker formation symptoms.
did the 2.2uF/9V capacitor trick and unshorted it, now reads fine but not sure how long for.
No loss of power, I've seen this before on PS3 diodes with short between BDA and Gnd and RD-BD but normally it doesen't recover even if the whisker is blown out.
-A
Shrad
Sat Nov 17 2012, 09:28AM
put a dab of nail paint at the ass of that diode ;)
Tetris
Sat Nov 17 2012, 03:23PM
Does it heat up so badly that spikes of tin form on it? o.o
Josh Campbell
Sun Nov 18 2012, 06:35PM
Josh Campbell Registered Member #5258 Joined: Sun Jun 10 2012, 10:15PM
Thermally induced stress is one of the mechanisms behind whiskering. The lead in solder used to impede this (vs using pure tin) but after it's ban the problem has reemerged. Zinc an silver can also form whiskers, so that lead free silver bearing solder can also be prone to the phenomenon depending on the alloy.
Pretty interesting, albeit annoying as hell. Link2
It's not the same reaction but it reminds me a bit of mercurys reaction with aluminum. Mercury Attacks Aluminum
Mon Nov 19 2012, 11:21PM
Its done the same thing again!!
Am going to send the module back, this is ridiculous.
-A
Ash Small
Tue Nov 20 2012, 08:35AM
2bytes wrote ...
Pretty interesting, albeit annoying as hell. Metal Whiskering
This link doesn't seem to work. It takes me back to the forum index page.
Josh Campbell
Tue Nov 20 2012, 02:45PM
Ash Small wrote ...
2bytes wrote ...
The forum didn't like that link. It was just the Wikipedia page for Metal Whisker, interesting stuff. Link2
Ash Small
Tue Nov 20 2012, 03:57PM
2bytes wrote ...
Ash Small wrote ...
2bytes wrote ...
EDIT: Nope. It's the brackets around the word 'metallurgy' that seems to be the problem.
Lol, that link takes me to the wikipedia page on whiskers (animal whiskers)!
This link might work!
It is pretty interesting when you get to it though.
(If you click on the 'quote' tab, you can copy and paste the link. It works then)
Wed Nov 21 2012, 11:11AM
It's Movember, whiskers are forming everywhere! :-{)
Josh Campbell
Wed Nov 21 2012, 04:24PM
Ash Small wrote ...
Google link shortener to the rescue. No cat whiskers here!
Need to add ( and ) to the forums link verification filter, regular expression, etc...
