  • Guests: 49
01/12 RoV IW3IPD (63)
So I found this on the internet... Hundreds of levitating balls!
BigBad
Wed Nov 14 2012, 02:27AM
The biggest problem is probably pulling the balls out the box to start with; you would need a many tesla strong field for that.
You might be able to use a superconducting coil; but fuck knows how you stop the balls just slamming into the magnet; I'm not an expert on superconducting coils, but I don't think they're very off-and-on able; although turning them off once isn't a problem.
Wed Nov 14 2012, 03:18AM
BigBad wrote ...
even if you can PWM a multi tesla magnet, how would that help? each ball would move up with different time and inertia, so pulsing the main field in the presence of gravity does little.
teravolt
Wed Nov 14 2012, 03:59AM
If this ever happened the junk yard magnet would have to have be a AC magnetic field because there are no power sources in the balls. that old magnet would never have a mgnetic field powerfull enough to lift anything ten feet in the air. fake!
Josh Campbell
Wed Nov 14 2012, 04:37AM
Josh Campbell Registered Member #5258 Joined: Sun Jun 10 2012, 10:15PM
Talking purely on a what if basis. I would say that the stationary magnet would have a constant Tesla. Each floating device would have to be individually addressable (nothing difficult there) and able to adjust it's reactance to the constant field (difficult).
Possible ideas to actually do something like this (just brain storming):
-A small, single electromagnet like what they showed in the video (small screw with wire around it on that board). Full on and it would shoot away or toward the large field. PWM the power level to maybe control the attraction, but the orientation is still not controllable.
-Multiple electromagnets say at minimum 3, one on each axis forming the shape of a "jacks". Throw in a 3-axis accelerometer and PWM control of each magnet and you now have the ability to thrust in any direction and measure that movement. Maybe add in a hall effect sensor at some distance from the "thruster" magnets to measure the field strength and orientation of the large field to give the craft spacial awareness.
-The above navigation controls but rather than traditional electromagnets use an aluminum ball with small coils placed on the axes inside the ball generating eddy currents in the walls of the aluminum ball and thus opposing magnetic fields.
Of course a big problem would be powering the ball while not weighing it down. Options there could be a form of wireless power, perhaps rather than a stationary magnetic field use an alternating magnetic field. A coil in the ball converts the field alternations into power. And the hall effect switch ensure that propulsion is reversed each time the field reverses.
I still think that the strength at which the large field would need to operate would make the device to dangerous and or not reasonably feasible. Maybe if the field could be concentrated in a smaller controllable area. Some type of halbach array. Maybe in the gap of a large U ferrite... I'm probably going to end up dreaming about some magnetic flying machine tonight, thanks again interwebz.
Wed Nov 14 2012, 05:11AM
yeah even moderately powerful magnetic fields can accelerate objects at lethal speeds/force. To 2byte's point.
macona
Wed Nov 14 2012, 12:55PM
macona Registered Member #3272 Joined: Mon Oct 04 2010, 11:40PM
Fake:
Tetris
Wed Nov 14 2012, 08:18PM
Fake or not, it still looks really cool. All I could think about is... you can buy almost anything that's known to humankind on e-bay.
BigBad
Wed Nov 14 2012, 08:29PM
Patrick wrote ...
If you put iron core into the balls, then they will tend to stick together and form one lump, and you might be able to control that lump, at least to some degree; but it will be fairly unstable.
Fri Nov 16 2012, 06:41PM
About the only way this might work is to put a small fan inside each ball to provide a counter force.
This would keep the stack stable, and with the addition of induction power and LEDs would make a 3-D display feasible.
Pinky's Brain
Fri Nov 16 2012, 06:56PM
What about putting a coil around a ferromagnetic core and dynamically connecting it to a tank capacitor? Wouldn't that oppose the magnetic field?
