  • Guests: 59
DRSSTC driver with flip-flop synchronizer
Gregory
Mon Nov 12 2012, 01:20AM Print
I was projecting a new driver for my future big DRSSTC, and junt now I noticed that the normal flip-flop synchronizer with clock attached th the feedback input will only reset the driver enable when tke feedback goes high, so it will have half chance of wait more than 1 cycle to turn off the driver when OCD trips and will not turn off at the end of the current cycle.
Maybe isn't better make some syncronizer that reset on the falling and the rising edge of the cycle? I think it can save some igbts, because it will prevent one more cycle off over-current.
Mon Nov 12 2012, 11:04AM
If you start switching in increments of half cycles, then it becomes possible to have a DC component in the gate drive waveform. I don't like the thought of that, so I've always used increments of one cycle.
Paul Benham
Mon Nov 12 2012, 07:29PM
Paul Benham Registered Member #570 Joined: Wed Mar 07 2007, 03:41PM
I was thinking the same and was going to use an XOR frequency doubler in the clock feedback used to do the reset.
If it does stop mid cycle would the core recover before the next burst I wonder? I had not thought about the DC.
Perhaps in a pulsed system there is some DC anyway from the coupling capacitor charging or discharging when it starts and stops.
So far I have only run CW, I have yet to get to a pulsed system so don't know the answer. One thing is for sure, the present system works very well, whether the extra complexity is worth it who knows.
Cheers,
Paul.
Gregory
Mon Nov 12 2012, 08:14PM
I was thinking in the XOR doubler too.. But only now I notice the possibility of DC components in the gate drivers.. But if I have a bleeder resistor at the output cap of the gate driver, it will drain all the DC componente that can be in the cap.
Ben Solon
Tue Nov 13 2012, 03:30AM
I'd be more concerned with the dc component in the core than the cap. But that's just me.
Gregory
Tue Nov 13 2012, 09:57PM
The DC comp on the core will go out because it will trip on the last cycle of the burst, so after it trips the core have some ms to reset himself.
