  • Guests: 39
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Oil type for HV transformers and coils
GammaRay
Sun Nov 11 2012, 06:47PM Print
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
Before going to the cost & lead time of ordering the core material to wind a custom HV inductor, I want to see if I can use an existing inductor that I will submerge in oil to see if that will suppress/resolve an arcing problem. Question is: What type oil is recommended to submerge HV transformers or coils in?
Thanks in advance.
Dr. ISOTOP
Mon Nov 12 2012, 03:16AM
Ideally, you'd use real transformer oil, such as Shell Diala.
Mon Nov 12 2012, 04:23AM
I have several threads on this matter, to save you the bore, you can use non-detergent motor oil, canola, olive or electrical device oil like diala or univolt.
i use canola on the large devices , and olive (yellow, virgin) on devices where the oils is part of the circuit, like my HV probe.
Shrad
Mon Nov 12 2012, 11:58AM
branded frying oil is also nice for this
resists oxydation and high temperature, and nearly free
