  • Guests: 41
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
First DRSSTC , Half Bridge
TwirlyWhirly555
Sun Nov 11 2012, 12:05PM Print
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Hi
After making a sstc and getting good results i thought id have a go at making a DRSSTC using the same secondary as my sstc ( Frez is around 200 Khz )
So after making a small single 555 interupter and half bridge i finnay got arcs :D
Specs are
Secondary - 4" Wide x 5" High , Fres of around 200 Khz
Driver is a PLL 4046 with primary feedback , only a 1:50 CT at the moment .
Half Bridge of 35A 1.2Kv IGBT's
Half Bridge Caps 1uF 1000v
15 Amp U Fast reverse recovery diodes
480v TVS Diodes Bi directional across C-E on IGBTs
18 Volt Zener Diodes on gates
10 Ohm Gate Resistors
1:1.5 GDT 10 T : 15 T
Primary Capacitor is poloyprop 117.5 nF
Primary Turns is 4
Supply 230v AC recitified .
I should put the filter caps at the bridge but ended up not doing it . I could get more out id say but tuning on a drsstc for me is still abit confusing and as my first DRSSTC im happy with the results , and no heating on IGBTs on lower breaks either , i do have a Oscope so i will scope primary current soon to see what it is . I have scoped the interrupter to make sure its working aswell
Spark lengh at lowest BPS i can get on my interrupter are 9.5 Inches .
Any pointers or tips would be great :)
Twirly .
8174810123 E662303d22
IMG_0039[1] by TwirlyWhirly555, on Flickr
8174848230 5fe001566c
IMG_0043[1] by
8174846326 Fdbb272b57
IMG_0051[1] by TwirlyWhirly555, on Flickr
8171903247 604deac66e
IMG_0029[1] by TwirlyWhirly555, on Flickr
Two Videos , long , shorter off times .
