  • Guests: 24
Jim_VE7UV (65)
07/24 Jim_VE7UV (65)
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
Sputter Coater Resurrection......
Tartan5
Sat Nov 10 2012, 02:32PM Print
Tartan5 Registered Member #7963 Joined: Thu Nov 08 2012, 09:06PM
Hello everyone!
I am very glad to have found this forum, I am thoroughly enjoying reading and learning from all the previous posts......
I have the guts to a sputter coater system (Vacuum chamber, pump, TC tube, target, etc). The main HV section looks pretty much toasted, and I am just starting a “digital” conversion to allow programmatic control of the unit.
The existing HV section was pretty simple: 120V in through a variac, feeding what looks like a 1:10 step up transformer, bridge rectifier / filter / current limit resistor to give approx -1000v DC out to generate the plasma. There was an output current monitor, and you just tweaked the variac to obtain the desired sputter current once the plasma is struck (and the pressure stabilizes).
My requirements for the output section would be 0 - 1100ish volts (for striking at fairly low pressure), but I want to be able to constant-current the output to be variable from 1-50 mA. Additionally, this unit is going to be around some EMC sensitive equipment, so I’d like to go as low-noise as possible.
I've been looking at various topologies, and was reading with interest the Linear Technologies APP note 118, “High Voltage, Low Noise, DC/DC Converters”, specifically the use of the Resonant Royer topology with soft switching of the transformer drive. I was thinking of using a current sense transformer to provide the feedback regulation. I would like to ask some opinions to the following questions, if I may:
1) Current Sense methodology: Separate current sense transformer or integrated HV transformer winding?
2) Current sense on input or output of transformer?
3) Is there a lower noise topology that could be used?
4) Any experience with the cheap, HV oscilloscope probes on ebay like: http://www.ebay.com/itm/NEW-300MHz-5000V-5KV-High-Voltage-Oscilloscope-Clip-Probe-USA-Seller-/120878612643?pt=LH_DefaultDomain_0&hash=item1c24ed40a3
5) Suggested sources for reliable HV transformers?
6) Any pointers on where to look for additional info (additional forums, groups, etc)?
Thanks for any insight you may have, and bearing with this first post :) . It looks to be a fun project!
Regards,
Tartan5
Pinky's Brain
Sat Nov 10 2012, 07:17PM
Tartan5 wrote ...
Why not just a shunt between ground and the substrate? (Or between ground and the substrate bias supply if present.)
Tartan5
Sat Nov 10 2012, 09:57PM
My thought was that if I had a conduction path to ground other than through the sample being coated (say an arc, or some catastrophic failure in the transformer or HV cable), I would still be able to sense and regulate the current, whereas with a sense resistor between the substrate and ground, the transformer may be forced to maximum output......
Perhaps that is less of a concern than I imagine?
(PS I really appreciate the input and look forward to further discussion!)
Best regards,
Tartan5
Pinky's Brain
Sat Nov 10 2012, 11:37PM
You can put a shunt between ground and the secondary too, but then you have to average.
Tartan5
Sun Nov 11 2012, 02:16AM
Just to make sure I know what you mean by shunt, do you mean a small current sense resistor, say 10-20 ohms? 20 ohms would give me 1 volt at 50 mA......
Is there a drawback to having either an additional winding on the transformer or a separate, small current transformer with appropriate burden?
Would a current transformer be more robust (less chance of being damaged) in case of an Arc?
