  • Guests: 40
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Laminated glass
Daedronus
Fri Nov 09 2012, 10:23AM Print
I need to make a view port on a vacuum chamber and I'm having a bit of trouble sourcing (at a reasonable price) a thick 6" glass disk and I was thinking of bonding a couple of 6mm thick disks with some soft of epoxy.
Would the laminate have comparable pressure resistance with a single piece of glass?
macona
Fri Nov 09 2012, 09:16PM
macona Registered Member #3272 Joined: Mon Oct 04 2010, 11:40PM
How thick are you looking at? You would be surprised at how little you need. A full vacuum is only about 15psi.
Daedronus
Fri Nov 09 2012, 09:52PM
Only 15psi means about half a ton for my view port area cheesey
I'm looking at about 14cm diameter window, 20mm of glass should be enough.
The only local company that I found want's about 80euro for a piece.
But I can get 6mm thick glass for a couple of bucks, cut to size, etc....
Ideally I would want a 300mm x 25/30mm disk, to have all of it clear.
Lower flange is ISO250, small one ISO63
Now I need a top.
I can have the aluminium stock machined for a smaller view port...or I could use a all glass view port.
1352498254 2329 FT1630 Img 4480p
Fri Nov 09 2012, 11:22PM
Daedronus wrote ...
Depends on the shear strength of your bond between glass surfaces.
Like sitting on a long bench made of two 3/4 inch thick boards, vs one 1.5 inch thick board.
Two layers of single thickness, if not connected together, have 2x the stiffness and 2x the strength of a single layer.
A single piece of double thickness (or two layers adequately connected for shear) has 8x the stiffness and 4x the strength.
If the 6mm stuff is so cheap, how 'bout doing a proof test with a single layer and full vacuum (or maybe even positive pressure -- could be hydrostatic). You could measure the deflection to validate your application of strength-of-materials formulas, e.g. Link2
Whatever one layer withstands, it would be conservative to expect multiple layers to withstand greater loads in direct proportion to overall thickness. The glue only needs to prevent air at ambient pressure from getting between the layers.
I can attest that acrylic plastic 12mm thick is plenty strong for a 150 mm diameter round window into vacuum. It deflects about 1/2 mm in the center.
As for adhesives, you might search the internet for lens cement and UV-curing cement.
p.s. the Internet page I cited mentions "Circular Plate Defection Moments and Stress". smile
Sat Nov 10 2012, 03:47AM
Bumping my own post w/ new information about Circular Window Thickness.
Hope you don't mind somebody investigating and learning on your behalf. Like you did in response to Gren's transformer design calculator. smile
This online calculator gives the minimum thickness of circular windows made of fused quartz. Link2
Is says that for unsupported diameter of 140 mm, thickness should be at least 9.5 mm.
Doesn't give the formula, but does say it uses a design stress of 1000 psi.
The result agrees with this online calculator: Link2 .
Another reference says "Rule-of-thumb tensile design strengths are typically at 1000 - 1500 psi for nominal glass materials." Yet another says "For most types of glass a nominal strength of 70 MPa (10000 psi) and a design strength of 7 MPa (1000 psi) are typical."
Here are two references that give the formula: Link2 Link2 .
The latter includes an Excel calculator pre-loaded with material strengths.
Looks like two layers of 6 mm glass would do it, without depending much on bonding strength (see previous post).
Not because calculator says 1 atmosphere requires 9.5 mm -- that would have to be one piece, or well bonded laminate.
But because calculator says 1/2 atmosphere requires 6.7 mm, with a good safety factor.
Hey, since you presumably have a vacuum pump, you might use a vacuum-bagging process to "clamp" your glass disks together while the laminating adhesive cures. How come you're using glass and not, say, acrylic plastic?
p.s. That's a very pretty stainless steel fitting you've got. Did you weld it yourself, or have it made specially?
johnf
Sat Nov 10 2012, 07:53AM
Nothing wrong with 20mm thick perspex
also some polycarbonates ok but some sublime making getting a good vacuum difficult
Ash Small
Sat Nov 10 2012, 10:10AM
Depends on vacuum required. All plastic (perspex, etc) outgasses to some extent.
Daedronus
Sat Nov 10 2012, 11:16AM
Thanks klugesmith, don't mind at all.
Ebay made it :)
I try to stay away from plastics for two resons:
They can outgass/sublimate/etc...
and, they react badly to plasma
I try to keep this as clean as possible, I'm aiming for single digit microns with my mechanical pump, or as low as possible if I also use my diffusion pump....
Sat Nov 10 2012, 06:45PM
you could use 6mm of glass facing the vacuum, then Acrylic 9mm or more, for safety and strength. then epoxy them together. if you dont abraid teh glass you may get future parting as the epoxy peels away though. if you do abriad the glass it may may things less transparent... a single thick pane of glass would be best.
2Spoons
Sun Nov 11 2012, 09:05PM
Abrading the glass would be a mistake - it would result in thousands of crack initiation points. You simply need to choose an epoxy with good glass bonding properties (as used in fiber-glassing), use a thin layer, and make sure the glass is absolutely clean before gluing.
