  • Guests: 55
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
house clocks and back up generators
Sun Nov 04 2012, 04:18AM Print
When I lost power due to Sandy my backup generator turned on. I noticed that my digital bedroom clock (it's from 1980) and microwave clock all ran fast. By the end of the day they were ahead about an hour. I measured my voltage and it was 125vac and about 63hz.
I would think that the clocks rectify the voltage and use a voltage regulator, but this does not seem so. Is it the higher voltage that is causing the circuits to run faster? Could it be noise spikes from the generator?
I'm running the generator right in the range specified in the manual (62-63hz, 123-126vac).
Mattski
Sun Nov 04 2012, 04:35AM
Some clocks derive their time from the power line frequency, 60 cycles per second. The frequency from the utility company is regulated so that even if the clock runs slightly fast they make sure to slow it down so that on average a clock that runs off of this should be quite accurate.
If your generator is putting out 63 Hz then it will cause your clocks to run 5% faster than usual (if they do use the line frequency), which works out to about an hour per day.
Sun Nov 04 2012, 04:37PM
For long term cumulative accuracy,
counting power line cycles beats any inexpensive crystal oscillator reference.
In fact it is as good as an "atomic clock" that receives time signals from a government broadcasting station. And even for short periods, the tolerable frequency deviaton is less than 0.1% IIRC (easy to look up on internet).
The above is not necessarily true in developing countries.
genious 7
Sun Nov 04 2012, 07:49PM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
Yep, its the line freq, not the line voltage. Many clocks use the line freq instead of a quartz crystal as it is more dependable; the power company regulates it so that on average, it is exactly 60hz.
BigBad
Sun Nov 04 2012, 10:59PM
It's certainly not as good as an atomic clock due to power failures, and the fact that the short-term frequency isn't constant either.
Electra
Mon Nov 05 2012, 06:13PM
Possibly the manual says to run at a slightly higher frequency, to allow for the Rpm to drop a bit under load.
What about a phase lock loop circuit to keep the genny locked to an Xtal reference, assuming there was some form of electronic actuator of the throttle position. Would that work or not? How do the power company’s archive such accurate frequency control, unlikely it’s still done by manually watching the freq.
lightlinked
Mon Nov 05 2012, 07:23PM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
last time I lost power it was fun to see how much the freq fluctuates using a kill-a-watt. $20 well spent for any geek
there are now small gens that use inverters. which of course would bring up the criticisms of cheap inverters. We're glad you are still alive and have electricity.
